Crazydetailer Foam Cannons
Pravin@crazydetailer
Turn your pressure washer into a super FOAMER with the CD Foam Cannon !
This foam lance produces clinging foam that you have only ever seen at car washes.
The benefit of using a foam gun to deliver the soap to the vehicle is that it doesn't require you to touch the vehicle, which could rub dirt against the paint. The CD Foam Cannon sprays the vehicle with a thick coat of soap to loosen and lubricate dirt. On dusty or lightly dirty vehicles, you may not even need to hand-wash. The Foam Cannon HP minimizes the amount of hands-on contact with the vehicle, which can minimize wash-induced swirls.
The CD Foam Cannon is capable of such a high volume of foam, a vehicle can be completely white'd out. The foam clings to vertical panels and provides the lubrication you need for a safe car wash. The foam provides a pre-soak that loosens dirt and grime so hand-washing is easier.
A vertical jet nozzle is included so you can apply foam or rinse in a sweeping side to side motion. This nozzle allows you to work around and then down the vehicle, which is the recommended way to wash a vehicle.
Fittings currently available for Karcher K Series Washers.
For more information click here
We've just unpacked our latest shipment ...
UpNcOmiNg!
Events Organiser
MMMMM!
I like!
So whats my price? hahaha! I joke! :thumbs:
Will buy when my M5 FINALLY gets sold
PS, Ebrahim, the details are on the website.
Shampoos recomended for use with the foam canon :
•Chemical Guys Maxi-Suz II (50ml Per Tank)
•Carways MegaWash (50ml Per Tank)
Thanks UpNcOmiNg!, you spot on. I've even found, using HOT water creates even more foam.
Phillip, this will fit all K-Series Karchers. Though the more powerful the machine, the better the foam. More pressure = more foam.
kabal
can you not get different adapters?
I spoke to Carn once, and he was able to get B&D adapters to use with those lances
You get different adaptors but we import only the K-Series adaptor. There might be a few HD connectors laying around from the last import.
Are you looking specifically for the Bosh fitting? I can try and source one for you.
ASH M
Cool product :thumbs:
Does it come with the K series adapter and what types of car shampoo can be used?
andrewbuch
WHich would be best for use with this
The KArcher K2.360 or K3.150 ?? Makro has both on special for same price, so was thinking getting the pressure washer now & foam cannon later??
Both will work exactly the same as the pressure output is the same. But I would go with the K 3.150. Slightly higher wattage rating and you get a slightly longer hose. It is a slightly heavier machine ... but its got wheels .. so who cares ?
andrewbuch
Thanks for the reply & the PM about the Cannon.. I have had to sell the idea to the wife, told her if we get the washer & cannon it will be easier for me to clean her car :)
outlaw335
Thanks for the heads up Andrew! Went to the makro website and saw the K3.150 going for R999.I've been looking for one so i think now's the time :thumbs::thumbs:
NavZ
What do they normally go for? Is the special only for today?
