Control arms
CK4LIFE
My E46 320i pulls sideways when driving at any speed. First i was told to replace the bushes but it it didnt work. Then i just replaced control arms but it's still da same. do i have to take it for alignment. will problem go away. Pls assist.
JayDrft
When you take it for alignment, ask them to check that your strut is tied in place.
on my e30, I never checked that, then all of the sudden I would hit a bump and turn left or extreme right by itself...some scary SHITE!
When replacing shocks, the guys showed me that the retaining plate that retains your coil spring and strut was worn, it had a slot in it...it wore a slt into it because it was lose.
Thats my 2 cents. Hope you get it sorted...Have your strut mounting rubbers inspected, they could also cause some faulty steering action. For those, expect nothing less than a grand from the dealers....:thumbdo:
D
Dippies
any work done to the Steering rack and or related parts plus Tyres it is recommended that you do alignment.
CK4LIFE
thanks mate...mine does the same thing...when i hit a bump it goes left or right without even turning the steering wheel. will check those strut mounting. Oh any iideas where in PTA i can take it perhaps.
No work has been done on steering rack..since i bought it anyway in 2011. I did however change rear tyres in Dec 2012 and alignment was done.
moranor@axis said:
what were the alignment numbers? half the shops dont do this properly...
I'm not really sure about the numbers but i took it to atleast two different shops. No difference.
