Confusing Part numbers when trying to find ZHP Gear Knob
AdiS
Howsit guys,
I was just a Auric Auto now getting pricing for a replacement ZHP gear knob for an E46 330i, and I'm a bit confused. There are two different part numbers for what seems to be the exact same gear knob - same description, everything, except one is cheaper than the other.
The part numbers are:
Gearshift knob,leather/M plaque/6-speed SCHWARZ 1 03/2003 25117896886 $79.00
Heavy version
03 Gearshift knob,leather/M plaque/6-speed SCHWARZ 1 03/2003 25117896884 $68.00
What the hell is the difference? I know Kabal got the 25117896886. They have the 25117896884 in stock.
Please advise.
A
AdiS
Sankekur said:
One might be weighted the other one not.
On RealOEM, it says 'Heavy version' on both descriptions.. i just didnt copy it properly :/
AdiS
Sankekur said:
Was there any differences on listed on BMW's EPK?
No, the only difference was the price. Maybe you're right tho, it would make sense with the price difference. Do you recommend the weighted version?
Sankekur
Yup, a heavier one tends to give smoother gear changes, especially if you plan on going for a short shifter as well.
AdiS
No, dont think im going shorter shift. Just want to replace the worn part.
Bayn46
I think the one that they have in stock will be the same dimensions as the stock shift knob, whereas the other one, that Kabal got, is a bit shorter and probably lighter. I'd prefer the second one.
AdiS
No, they are the same size as shown by the diagram.
Brendon.Myburgh
i just took a peek at google images
25117896886 - looks like an E46 M3 Shifter
25117896884 - looks like an E36 M3 Shifter
perhaps its just my imagination but they do look somewhat different.
Bayn46
Checked Realoem, the 25117896886 (Part #3), looks shorter than the other ones. I wouldn't bother with the other one being that it's the same size as the stock knob.
AdiS
Yes, but look closely - 'part 3' has two part numbers listed as per my earlier post. Same description, same image.
S
SP33DYV
Why do you wanna change? Wait till you get the car on Monday and have a look at the gear knob first.
Sent on the run from my iPhone using Tapatalk
AdiS
I'm definitely going to check it before, I just noticed some wear in pics. So I was looking into it pre-emptively. Its just a way im keeping myself occupied.. ;)
kabal
I definately got part #3 on that diagram
if there is indeed a heavier once, it must be super heavy, I am sure that you could easily kill someone with the one I have :rollsmile:
it (just the shifter) is more than double the weight of the original e46 m3 shifter+boot
