I have a 1994 E36 318i auto with a 318is engine. I would say about half the time the starter only clicks, but not turn.
I got a new battery last week as mine died and the week before that fitted a relay at starter as sometimes nothing will happen when starting with key. i had to open the bonnet and short the starter with flat screw driver. This does not happen anymore.
Now half the time it only clicks. After 2-3 sometimes 4 tries it works. I have checked a few things that may or may not be part of the issue.
With engine off the voltage on battery is about 11.7v. it should be 12.2-12.6v. This voltage is the same on starter and the battery jump terminal in front with engine off.
When starting the car, the voltage at the same places remain the same when revving to 2000rpm. The cable at the back of alternator measures 14.5v at about 2000rpm.
The alternator is a bosch 90(not sure which number is the model). Not sure if the regulator / brushes should be replaced just in case? But the output seems good and within spec meaning between 13-14.5v?
From what I can see regarding the voltage. Not sure if the thick cable from alternator runs directly to the starter thereby going straight to the battery? If this is the case, I think this cable needs to be replaced? It looks like a braided cable. Are those not normally used for earth?
I do not think this is related to the clicking issue and if the lower voltage is normal. I tested by connecting powerpack to my battery and it clicked once and turned on the second try.
What would be my next step? The starters brushes were also replaced about 3 weeks ago.
