wallyengles said:Does yours have one tweeter or a mid and tweeter in each front door? Its fairly simple to replace the one tweeter type with a split system. And for the two speaker type you get a three-way jbl system that fits right in. I fitted these to my old cabrio and it made a huge difference!
Raybimmer said:Only took out factory speakers and put Sony Explode speakers in .
Yuvan said:Just remove the covers underneath the dashboard on both passenger and driver side(just above the foot space), then the plastic cover that shields the speakers can be easily removed, the plastic shields have screws holding them.
To remove the plastic shield on the driver side is the same except there is a bonnet catch handle situated there which has a screw as well so u need to remove that handle as well.
Its not difficult just be patient and careful with the plastics and keep all the screws u removed in a container and not left on the seat causing bruises on the leather ....i did mines and i managed to fit 6'' mids on both sides with ease!!!
I dont know if there is an easier way with the door speakers but when i changed mine i removed the door panel, unfortunately when doing this it is inevitable to avoid breaking the clips around the door panel, so be sure to have a few of those clips at hand!!
Enjoy!!!
LPM320 said:Hi Mcfly.
I replaced my mids in the kick panels with 6'' mids, that was almost a perfect fit. With regards to the speaker next to the accelerator, you will have to remove the panel the covers the part of the dash under the steering, as well as the bonnet release mechanism.
If you going 6'', then you are going to need to some work on the bonnet release mechanism, as it wont clear the speaker frame...
McFly said:Yuvan said:Just remove the covers underneath the dashboard on both passenger and driver side(just above the foot space), then the plastic cover that shields the speakers can be easily removed, the plastic shields have screws holding them.
Enjoy!!!
You explained it so well. I'll let you know once I'm done. Thanks.
