Hugo_za
Hey folks! Finally pulled the trigger and got two of these units from AliExpress for the X5 and 650i. Both have iDrive NBT. Installation was simple enough. Cable management was tricky due to the way the MOST cable has no play. Simply removing the MOST cable from the cable sleeve solved this. Once It had more play everything fir neatly behind the head unit. I routed the WiFi cable up along the LVDS cable and stuck the antenna to the back of the display.
Package Content
Installed and working
The unit started right up after everything was connected. I was worried when I saw the mic and AUX connectors in the included harness, but neither of those are required since the audio is routed directly to head unit (albeit still through the aux channel) and uses the car's built-in mic. I figured that the harness is made to fit pretty much any car's hardware configuration, which is a nice touch.
As with most of these units, Android Auto out of the box does not utilise the new widescreen layout. This is easily fixed with a custom firmware (Courtesy of Firefly1337 on the F30 forum). Flashing it takes a minute and comes with several tweaks, most notable of which is the widescreen Android Auto implementation.
Since it uses the AUX channel the track info etc does not display on the cluster or HUD, nor do the track up/down show but you can set the unit to allow the audio wheel to navigate the display which is the next best thing.
After the initial setup, the Android Auto starts up in under a minute after getting into the car. No need to connect the phone with USB.
Package Content
