Car start
Chris1
Hi i have E90 320i, problem is with starting, it takes couple of seconds to crank be for it starts and sometime when parking somewhere for and hour or more it won't start and will need jump starting to start. please help.
Nick
Hi.
Take the car to have the codes read, from there you will know what is broken and then it can be fixed.
Its the only way to get things done without replacing 19 " it might be this " parts.
Chris1
Nick said:
Hi.
By codes read you mean diagnose?
Nick
I do yes.
you need the car to be put on the computer to pin point what is broken.
Chris1
Will the diagnose help to get the problem as the car now starts but take couple seconds to start or could be cam shaft sensor, please help.
momo1
Could be one of a multiple of problems such as valve Tronic motor which is common issue, Fuel pump or filter, plugs, Battery , coils etc.
best you have it diagnosed first before assuming..
Chris1
hi everyone
My car came back from diagnose and the outcome fault was a radio which consume high voltage, so BMW took out radio for checkup and repair.
thanks again for advice.
Chris1
Good afternoon
I have found out that the problem was caused by the connection of tracker which overcharge on my battery and I'm waiting for their technician to fix the problem at 15:00.
Anyone know mechanic to help change the stem seal valves at a reasonable price>
Thank you.
zippy320
I found BMW dealerships to be the cheapest at this repair , and you wont need to remove the head .
Chris1 said:
Good afternoon
Thank you.
NtandoN
Chris1 said:
Good afternoon
Thank you.
Contact John Lodder at Leo Haese Bosch.
