rick540 said:No other silvery sticker inside the fusebox?
Not that I could see.
rick540 said:...give me the approximate build date and details of the car I can maybe find a vin "range" it has to fall into. Why do you want the vin so bad anyway, it's been re classified anyway and I don't think you can change that?
gconry18 said:rick540 said:...give me the approximate build date and details of the car I can maybe find a vin "range" it has to fall into. Why do you want the vin so bad anyway, it's been re classified anyway and I don't think you can change that?
One vin decoder site found my stolen/recovered vin to be:
Chassis number 0401712
Vehicle code 0411
Series 259S
Model R 1100 RS 93 (0411 ( 0416) )
Body type 0416)
Catalog model ECE
Production date 1994 / 05
Engine R 1100 RS 93 (0411
Transmission
Steering
Catalyzer NONE
Realoem does not recognize my vin and nor does BMWsa or other vin decoder sites.
I want the vin to find out what year model my car actually is and what options it had. I also want to know if it was originally a manual and then swapped to auto or if it is originally an auto.
etc, etc.
Will try the DME now.
gconry18 said:Rick... THANK YOU SO MUCH.
Found my vin on the DME.
Last 7 digits are: FJ24602
It is a South African
01/1994
Manual
Maybe that explains the 0-100 times of 10-11 seconds. The car probably still has the manual diff.
Where could I find a full build sheet?
Raybimmer said:Good luck with VIN .
Manual diff was 3.15 and I think auto was 3.46 . -Will be on plate on the diff .
0-100 in 8.8 and 120 in 12.0 according to handbook , with 328i having 8.3 and 11.5 . ( Both auto )
akash said:If you still have the original glass windows on your BMW it should have the last six digits of you VIN on it.
gconry18 said:@Rick, how can I get to the steering column section you described. I pulled out the cluster but couldn't see where the column bolts to the chassis.
DME box is still the only vin location. Need to confirm it in one other place before taking things further.
rick540 said:gconry18 said:@Rick, how can I get to the steering column section you described. I pulled out the cluster but couldn't see where the column bolts to the chassis.
It's usually take cluster out and look downwards, it should be obvious if it's there, but not all of them have it.
The only other logical place now is the VIN would be printed on/in software from the cluster.
gconry18 said:rick540 said:gconry18 said:@Rick, how can I get to the steering column section you described. I pulled out the cluster but couldn't see where the column bolts to the chassis.
Can a diagnostic read a vin from the DME as well as the cluster?
rick540 said:Yes it should be able to.
gconry18 said:rick540 said:Yes it should be able to.
So.... You busy this weekend? :=):
