Ok, this is for all the clever mechanically minded people, maybe they can help. When doing the brake pad change, how thick should the disk still be? Maybe we can post here for the various models, particularly interetsed myself for the E12 535i(M)
no you change the pads, if you have less than that left on your brake pads then you are increasing the risk of over wearing or damaging the brake discs. if you have worn discs the pad should be changed more regularly i.e., they will need to be thicker. If your brake disks are very worn then you will need to replace them too
I don't know the exact measurements but this applies to most vehicles. Rather don't take chances
Agree fully, looking for the specs so that I can measure, think other people might be ineterested too, as to how thick disks should be...
got the caliper.........ready to measure!
interesting part as to how thick they should be when you can still give them a quick skim.....
