Brakes advice 2008 120d
meljag
I need to replace my back brakes been calling BMW but their prices are not what I want to pay right now been considering getting the rear pads and discs from Incomex or Brembo rear discs and ferrodo pads. I don't drive harshly (sometimes) my car isnt standard and has software hence the sometimes... any advice?
///M Individual
What brand is Incomex offering? They usuallly stock Textar which is good. You can also check with Goldwagen for decent german brands like Febi etc.
Stay away from the Brembo (Doubt its the same quality as proper Brembo brakes) and Ferodo.
meljag
Thanks so much for the response. Incomex pads TRW and Swag discs they don't stock Textar anymore
rodga
Goldwagen pricing using part numbers from realoem - ex vat
31082A BRAKE PAD SET REAR - SUREBRAKE
31082B BRAKE PAD SET REAR - PAGID
31082C BRAKE PAD SET REAR - TRW
31082 BRAKE PAD SET REAR - FEBI
32723 BRAKE DISC REAR - MEYLE PD
32723A BRAKE DISC REAR - SUREBRAKE
meljag
Updated with brands, should be for all branches but this is from the centurion
Updated with brands, should be for all branches but this is from the centurion branch
I called Centurion now they have Febi pads and Surebrake discs. No other discs, are Surebrakes good? I don't want the car to squeal that sound is soooo irritating 🙂
rodga
No idea haven't used any of these brands before.
///M Individual
I would go for the Meyle Discs and Pagid pads from these
KPM3_30
Moderator
Surebrake Discs and TRW pads will be perfect. Many mates have tried the same combination on a few different BMW models with only good things to say, going the same route on the X3 when it is time to do the brakes. No complaints of squealing or any other untoward results.
The Surebrake discs come coated (like OEM), so they don't show rust like most of the other aftermarket brands after getting wet.
meljag
Thank you so much this advise is really helpful 😃
