Brake Light
speeddemon
So i changed my brake pads on my car on friday e46 330i and the brake lights still stays on. I did replace the sensor as well.:thinking:
Does onyone knows how to reset the light or did i do something wrong?
I'm thinking of disconnecting the battery and hope that it will do the trick but i'm not sure though.
Any advise please guys?
Hellas
You can try disconnecting the battery, hopefully that will do the trick. The light should reset itself. As with ALL electric/electronic stuff on your BMW, ALWAYS ALWAYS ALWAYS disconnect the negative battery terminal before working on anything.
zaleonardz
You should not need to reset the brake light as far as I can remember.
I know cfroc also had an issue, unplug your brake sensors, and see that they read close circuit using a meter.
speeddemon
Thanx guys:thumbsup:
Hellas i'm gonna unplug the battery now and:banghead: of me to not have disconnected the battery when i did the brakes.:hammerhead:
