Hi
I have the same problem as most other on the boost issue
I have a 320d 2004 e46
when I bought the car 6 months ago there was no boost so I returned it to the garage they took it in and it was repaired. I found the printout of the fault code in the car and on it was boost sensor.
everything was fine but the car did not have much power but I did not know how much it should have. last week there was no boost again I did not want to take it in as they would charge me for the diagnostic so I first wanted to see if I could check the sensor. while searching I found all the other stuff to look at and came on the suction tubes that was broken now I replaced those pipes and the boost is there now but also only at 3000 RPM and not much but the power that was there was not that much to start with. how can I check the turbo if everything happens as it should and how do I get to it and all other suggestions is more than welcome
