Guys
From you experience . What will be the issue/issues if there is 0 boost .
As soon as pedal is pressed a bit hard it triggers the half engine light and fault code 0030FF fault code .
checked all vacuum lines all seems fine . Car feels dead . No turbo spool . No turbo noise at all . Feels like no boost from the get go .
Noticed at idle that the line coming from the brake line near the airbox. when disconnected at idle as strong suction at bottom of pipe . when put back on and checked vacuum above canisters . Cannot feel anything .
Any ideas?
Also is there any o rings i must change on the intercooler side for safe measures ?
Any ideas?
