BMW M140i LCI Shadow Edition
Salt
This is where multimaps shine, allows you to quickly switch between 4 different maps.
So if you are out of ethanol, change the map and you're good to go.
Being forced to run an ethanol mix all the time for a car which one uses as a daily is not ideal, especially if you're going on longer trips.
You'd think so...but my current scenario it doesn't really solve my problem. I also just want to say - I am no expert at any of this - but I am the type of person that likes to understand things so I am doing a lot of research online, talking to people and engaging with Bootmod3.
To mention - something I've learnt along the way - the Octane Bootmod3 (and overseas) refer to is not as I knew it. They refer to ours as RON - theirs as Octane. So, 91 Octane is equivelant to +- our 95RON pump fuel. Also, our fuel is not that great and octane is low. So to run on 95pump fuel alone, a 91 Octane map is recommended. They have an ACN91 map - this is specifically for Arizona, California, Nevada, Canada as their fuel quality is particularly bad. I am currenty on the ACN91 file - this was recommended for me by the Bootmod3 seller/initial installer. The ACN91 file accommodates more for poor fuel than the 91 Octane file would. Please show my some grace if I inaccurately state something - learning curve here.
If I want to add the TU Pump, I have to go Stage2 + for the ECU to use the better pump, but on the stage 2+ multim, there is no option for the ACN91 file. Based on logs I have done, running 95 pump on the ACN91 file - there were timing corrections - withing safe limits and not bad, but if I were to go to the 91 Octane file, I have to assume the timing corrections would increase - so not sure where that would leave me. Some say don't worry about the timing corrections - its what the ECU is there for - others say don't ignore it. I generally prefer to caution on the safer side of things. Right now, I am think stick to the stage 2 Multim file, run the ACN91 on just 95 pump fuel and change to the 91 Octane file when adding ethanol. I won't have the extra power from the TU pump but frmo what I understand, it will be safer. Maybe I am completely wrong. (worth mentioning, I am not building a race car - more power is fun to use safely, but I am not chasing numbers - reliability remains no 1).
Stage 2 Multimap offers:
Map1: ACN91 +19HP
Map2: 91 Octane +24HP
Map3: 93 Octane +26HP
Map4: OEM MPPK
Stage 2+ Multimap offers:
Map1: 91 Octane +29HP
Map2: 93 Octane +43HP
Map3: E30 Octane +47HP
Map4: E50 Octane +50HP
Salt
I never leave home without a bottle or two of ethanol lol.
I saw you in a couple of rock vids.The car is sounding beastly.Any plans to go to tarlton?
Hahahaha - Mr Prepared!
Thanks, appreciate. Not really, won't pass the opportunity to go though - I am not really building a race car - but I do enjoy some runs in a safer environment.
jayaynikkal
Would an upgraded charge cooler be worth considering? While it’s separate from the engine cooling system, the B58’s stock unit tends to heat soak quickly, especially at Stage 2+. Keeping IATs under control can make a big difference.
Salt
Just installed a brand new OEM one - see last update post :) Also, not really a race car build so OEM is OK for me. But you are def correct - if I were pushing numbers and times if would def be something to consider!
Salt
Hi everyone, hope you are all well out there!
Small update since the last post in January...I will explain the changes and work first and then post the updated list for record after.
I have since futted the TU HPFP. Afrer starting to test different % ethanol mixes it started getting fuel pump errors. The TU pump fixed the issue right away. I am now running between two maps - BM3 Stage 2 ACN91 and Stage 2 91 map - mostly on the latter with an E15 mix. The ACN91 map I use if I am only running 95 pump fuel. Logs are good and confirmed by Bootmod3 as well. 294kW and 580nm on the wheels - happy.
The past 2 weekends I've started with the suspension refresh project. I can confirm I have since completed replacing a total of 12 control arms. This includes:
Front left & right tension struts
Front left & right wishbones
Rear left & right trailing arms
Rear left & right track struts
Rear left & right control arms
Rear left & right guiding suspension arms
I didn't use new bolts for the fronts, bit I did buy all new bolts, nuts & washers for the rear. However both front and rear bolts/nuts were all torque'd to spec with the wheel hub at its resting height. For reference these arms had all done 113k km and are 8 years old in August.
Check the video below.
Video comparing the difference between new and old control arm
Below some pics of the rear suspension work and arms. I must say, the fronts looked much more worn than the rears, however after a full alignment done on Saturday, the improved handling is very noticable. There is a specific bend I take on the way home - the target is always 120mk/h - was previously doable but a little uneasy - now its completely settled around the bend.
WhatsApp Image 2026-06-30 at 17.58.09 (1).jpeg WhatsApp Image 2026-06-30 at 17.58.12.jpeg WhatsApp Image 2026-06-30 at 17.58.16.jpeg WhatsApp Image 2026-06-30 at 17.58.17.jpeg
WhatsApp Image 2026-06-30 at 17.58.22.jpeg WhatsApp Image 2026-06-30 at 17.58.24 (1).jpeg
WhatsApp Image 2026-06-30 at 17.58.23 (1).jpeg WhatsApp Image 2026-06-30 at 17.58.26.jpeg
WhatsApp Image 2026-06-30 at 17.58.23.jpeg WhatsApp Image 2026-06-30 at 17.58.25 (1).jpeg
WhatsApp Image 2026-06-30 at 17.58.22 (1).jpeg WhatsApp Image 2026-06-30 at 17.58.25.jpeg WhatsApp Image 2026-06-30 at 17.58.13 (1).jpeg
WhatsApp Image 2026-06-30 at 17.58.14.jpeg WhatsApp Image 2026-06-30 at 18.48.45.jpeg
The car has since gone in for a CBS service at BMW we as well.
I've already bought new engine mounts and gearbox mount PLUS a set of ISC Street Sport Advanced coilovers - arrived a few weeks back. The offer height adjustment, 32 setting damper adjustment (manual) and camber adjustment. They also come with new drop links. These and the engine/gearbox mounts will be fitted next week to the car - this I won't do myself and will go to SCS.
I am still considering changing the injectors as preventative maintenance. There are various reports of the injectors failing on the B58 Gen 1's - and again some don't. Mine are on 113k km now and do use BM3 to check fuel rail pressures after a hard run for any leakage but they are good still so not sure on that one yet. As for suspension - that will be almost completely new end of next week and considering the new coolant system that was fitted (see Jan 2026 post for context) my focus will move towards injectors/coil packs next I guess for maintenance.
I'll do a post after the coilovers were fitted!
Salt
Just for recored keeping pusposes:
Upgrade list from the previous update:
  • Gloss black kidney grilles
  • Gloss black front lip
  • Gloss black side skirt extensions
  • Gloss black rear diffuser
  • Gloss black rear side splitters
  • Gloss black mirror caps
  • Gloss black Roof Spoiler
  • White V brace covers
  • Carbon Fiber steering wheel trim
  • Carbon Fiber handbrake grip
  • Carbon Fiber Gear trim and surround
  • Gloss black eyelids
  • (the above all supplied and fitted by @Rennzport )
  • M Performance mats
  • M Logo door puddle lights
  • M logo tire valve caps
  • M Performance pedal covers and foot rest
  • M Performance carbon fiber fuel cap cover
  • (the above all supplied by @deago.parts@abmbmw at BMW Midrand)
  • Full frontal PPF
  • New style gloss back Roof Spoiler
  • RGB DRL's (@FiRi@Rennzport )
  • Orange Alcantara Stop/Start button trim (Ali)
  • Custom dashboard wrap & alcantara trim (ASG)
  • Custom centre arm rest alcantara upholstery (ASG)
  • New steering wheel carbon fibre trim & emblem (Ali)
  • New Carbon Fibre paddle shifters (@FiRi@Rennzport)
  • Carbon Fibre centre trim and door handles
  • New M Performance door puddle lights (@FiRi@Rennzport)
  • M Gel badges (UK seller)
  • Sunglass holder (Ali)
  • Ultra Racing Engine brace
  • BMC air filter
  • Custom air box lid
  • Downpipe (TMSS)
  • Bootmod3 Stage 2
  • XHP Stage 3
  • BMW OEM rear chassis brace
  • Emerald Boot Struts installed - the tailgate actually opens from the key fob - still manual close but makes life a little easier (Emerald UK imported)
  • Intake resonator removed and PSH silicone hoses installed (PSH UK imported)
  • I did the usual Bimmercode adjustments - stops/start out, door handle lights for reverse, Carplay full screen, window interrupt etc.
  • New Bosch TU HPFP fitted 2026.
Maintenance/Repairs:
  • The usual services on going - after the MP expired I took out the BMW My Service Plan and Extended Warranty.
  • I do oil services in between the CBS services.
  • In 2024 the main coolant tank and main water pump failed - that was replaced under MP.
  • June 2025, pretty much the rest of the coolant system failed and was replaced at BMW - 5 pipes and connectors, Aux water pump, complete new intake manifold/charge cooler, oil filter housing.
  • Several door locks fixed by BMW - usual F series issue. Apparenty they now have a revised fix for the issue 2024/25/26.
  • New radiator mesh guard installed 2025.
  • New battery 2024.
  • Front new brake pads 2025.
  • Rear new brake discs and pads 2025.
  • Brake fluid flush 2025.
  • Gearbox service at ZF 2025.
  • PCV replaced as preventative 2025.
  • December 2024 the car underwent a detail at Izimoto - included Gyeon exterior ceramic for both paint and PPF, leather and glass.
  • August 2025, I removed all the wheels and the bash plate, had the car on my home ramp and did a chassis/wheel well decontamination and clean.
  • December 2025 - I removed the front seats, shampoo washed the carpets and boot area, cleaned and steamed all the leather, cleaned the subs and then did fresh Gyeon leather shield.
  • Now running Michelin PS4's since end 2024.
  • New front left & right tension struts fitted 2026.
  • New front left & right wishbones fitted 2026.
  • New rear left & right trailing arms fitted 2026.
  • New rear left & right track struts fitted 2026.
  • New rear left & right control arms fitted 2026.
  • New rear left & right guiding suspension arms fitted 2026.
  • Gyeon Ceramic topup coat done June 2026.
Salt
Some updates...
I want to say (not sure if I have before) that knowing what I know today, the first upgrade/mod I should have done on the 140 is suspension. Nonetheless, I ordered a kit from Ultra Racing - ISC Street Sport Advanced kit. Damper, height and camber manually adjustable kit. I did plenty homework and pricing checking. In the end, it was the damper adjustability that swayed my decision from ST to the ISC kit - when comparing similar ranges/prices. The ST kit is fantastic and carries a good reputation, so take nothing away from that kit. The ISC kit is manufactured in Vietnam and assembled in the US.
I was very concerned about lowering the car more than stock. The added aero kit lowers it by around 10mm already and some entrances were tight as is. However, I guess the bug bit me and I ended up lowering the car by 20mm front and rear. I have since driven with 4 people in the car and with the spacers still on (12mm front and 15mm rear) no touching or rubbing. It's also quite a pleasure looking at the car and the new height...smaller wheel gaps. It does mean I need to give some consideration at times but must say its few and far between so not a big deal really.
Handling has improved vastly - and of course it's a combination of complete control arm overhaul front and rear, new engine mounts (which were def finished) and the new springs/shocks. Cornering carries way more confidence and acceleration to an extent as well. I know I have a rear diff bush that has started tearing and needs to be replaced plus the Powerflex rear diff front and rear inserts have been on my list for a while...and I think those will be the final upgrade/maintenance item on the suspension during my ownership that I will do. The latter items I think will improve the control/feeling under hard acceleration as much as possible or up to where I am willing to go at least.
I must add - I have a very weird faint clunking noise when driving slowly and going over small bumps. Spring preloads have been checked, I've checked the front top mount nuts and all good. Car will be going back to Ultra Racing to investigate. They have been excellent with regards to after sales service - never hesitates to respond, give advice, guidance and continues to follow up. The last comms was to request the car to be brought back to investigate at no cost. The faint clunking could be due to anything, possible not even the IST kit but they continue to assist.
The ride quality is honestly also excellent and 100% better than stock. I currently have the dampers set to 16 - which is in the middle of the band - there are 32 damper set points and I happy as is. For any track days I might tighten it up a bit. But I am very satisfied with my choice. I'll share some close-up pics of the wheel gap comparison in the next post for interest's sake.
Before...
After...
I did a nice little interior upgrade as well...coming up in the next post
Greenz
Not too high and not too low.Very nice.👌
Mo from Ultra is a legend.Very helpful and knowledgeable.
Anees
Looks fantastic bud!
Regarding the faint clunking noise when driving slowly and going over small bumps, I experienced the same after fitting my coilovers. Uncle Mo adjusted my end links and it was sorted
Salt
That is excellent news, I am not worried that they'll sort it.
Quick///M
Some updates...
Before...
After...
Wow that is quite a difference looks much with this ride height, nice stance!
