BMW E90 NOT STARTING
Heathcliffe
Hi guys....i have a 2005 BMW E90 320i...car was working fine the whole day...went to the mall with family...after about 3 hours or so..all got back in car...inserted the fob key...all the bells and whistles light up.....pushed the start engine button...and there was a slight humming noise..and car refuses to start.....started the procedure again...and car still refuses to start...just silence...but everything else works...the clocks needles work..but will not even crank...had to get the car towed home...
Any ideas would be appreciated.. .oh..car has a 652 power rated battery inside that's about 5 months old...
husaindindar
Why was the battery replaced 5 months ago?
Possibly something draining battery and might have killed the last battery you had?
Or maybe this new battery is also dead, babies also die!
To me sound like the battery doesn't have the juice to turn the starter.
Just my 2c.
Good luck, hope you get it working again!
Heathcliffe
I changed the battery cos the original battery in the car was damaged...car was standing in the open for 2 years...without being moved or started...so I put a new battery in the car when I got it...i tried to get the car boosted from another ...bit it disnt even swing or crank...still the same silence...
Ratslaaf
Hmmm, it might be that the actual starter has failed. It's not an uncommon failure on N46 engines. Thing is, the car stood for two years. Ideally, the car would need to be checked out properly as there might be a few other issues at play here as well. It's recommend to replace all fluids in a car if it wasn't running for such a long time, especially if it was standing outside in the elements.
Your only real course of action would be to get the car to a trusted mechanic to have a look.
Heathcliffe
The car was standing for the 2 years..and I have been using it dir the past 2 months continuously.. ..
AlexYannoulatos said:
where did you connect the jumper cables?
[/quote
I connected them in the front...not by the battery in the boot...is that wrong???
The starter on my 2005 e90 320d has failed spontaneously before, so it's not impossible. Driven during the day then parked at home for an hour then simply not starting or even cranking. I would suggest getting it scanned for errors?
momo1
Eish could be a few things..
Fuel pump?
Starter Motor?
Vrot battery?
or the dreaded valvetronic motor :RedNo:
whats the progress? did you get it scanned for any errors?
Heathcliffe
Fuel pump?
Starter Motor?
Vrot battery?
I managed to jump it from my other car direct to thw battery in thw boot...and it fired up in one swing...i idled ot for about 20 minutes...switched it off..tried again and it fired up good...left it to arand for about an hour...thwn went back..teied to start it and nothing..a very weak short swing and ....nothing...went to a barttery place today and thwy auggested that thw battery i am temp uaing from my Polo..is not atrong enuf for it...in twrma of Amperage...i need a batteryvwith a amerage of at least 80amps...and the 652 from my polo is probablyvonly puahing out about 65amps...
Mia225
i had this same issue on my E90 335.
was still driving. switch off and when i wanted to leave home again, nada.
everything comes on. pump pings etc. JB4 couldnt pick anything up.
got it towed to a workshop. was my starter. after doing some research it was found that due to the position of the starter - its a common fault, specially on the E90's that the starter will just fail without any signs... :RedNo::blueCry:
Heathcliffe
And to change the starter is a big mission i believe...
Mia225
Not actually... Can be done within a day...if you have a replacement starter. Mine took 2 as i did recon on my
Sent from my LG-H815 using Tapatalk
Heathcliffe
Think i need to change the battery firat for the correct size and amperage first
Spiro
Check
Battery
Make Sure Registered
Make Sure Alternator VR Module is fine
just reading above... the car can crank when boosted... so the starter is probably fine ??
Heathcliffe
Spiro said:
Check
Battery
Howsit...thanks for reply...what is thia registering of battery...?? i went to our battery dealerships and they told me i can juat change thw battery...thwy have nevwr hears of registering a battery on the BMW
Spiro
Heathcliffe said:
Spiro said:
Check
Battery
for the e90 models, as far as i know you need to use a tool like INPA to register that you have a new battery placed into the car, or it will keep in memory that you have an old battery and fade out the rate of charge...
this could be causing the issue currently that the battery is not charging optimally
Denver Govender
Hi All, I humbly appeal for anyone to please help or advise me...I have a  320i-2005-e90-Manuell. I am having problem starting the car..I have to go through a few attempts pushing the start and stop before the engine turns and starts. This morning when i pressed the start button nothing happened ..after 3 attmepts inserting the fob key in and out it started...I am mechanically minded ..and have tools to do a DIY...and will highly appreciate any help regarding the issue that I have I am based in Randburg JHB, My whats app is 072-374-5643. Not sure where to start..I have check all battery terminals, and I know the battery is only 1 year old..i just bought this car a month ago.........really would love to learn and willing to do anything for help..God bless/
[font=Tahoma, Verdana, Arial, sans-serif]Hi All, I humbly appeal for anyone to please help or advise me...I have a  320i-2005-e90-Manuell. I am having problem starting the car..I have to go through a few attempts pushing the start and stop before the engine turns and starts. This morning when i pressed the start button nothing happened ..after 3 attmepts inserting the fob key in and out it started...I am mechanically minded ..and have tools to do a DIY...and will highly appreciate any help regarding the issue that I have I am based in Randburg JHB, My whats app is 072-374-5643. Not sure where to start..I have check all battery terminals, and I know the battery is only 1 year old..i just bought this car a month ago.........really would love to learn and willing to do anything for help..God bless/[/font]
[font=arial, sans-serif]Hi All, I humbly appeal for anyone to please help or advise me...I have a 320i-2005-e90-Manuell. I am having problem starting the car..I have to go through a few attempts pushing the start and stop before the engine turns and starts. This morning when i pressed the start button nothing happened ..after 3 attempts inserting the fob key in and out it started...I am mechanically minded ..and have tools to do a DIY...and will highly appreciate any help regarding the issue that I have I am based in Randburg JHB, My whats app is 072-374-5643. Not sure where to start..I have check all battery terminals, and I know the battery is only 1 year old..i just bought this car a month ago.........really would love to learn and willing to do anything for help..God bless/[/font]
