BMW E46 M3
twincam nc
Howsit gents
Im in the pipeline now for buying a other car
WHat i would like to know is what is your guys views on this car
Bad good pro's con's
Input would be highly appreciated
v1p3r
twincam nc said:
Howsit gents
Howzit man, great car you're looking into
There are plenty of "buying an E46 M3" or "what to look out for" threads around
W
wikk3d88
at minimum, if it has no motorplan left (highly likely), you will need 15 -20k per year for maintenance.
Crash_Nemesis
Run the codes. If the car is running lean. Walk away... I just paid massive cash to fix the problems from an e46 M3 that was running lean. Damaged Valves and exhaust cam which destroyed a piston.
Check if any service was done to Vanos and other Engine work.
These S54 motors need constant maintenance because of the brutal thrashing they take. If properly maintained, they are awesome machines and will last. But you never know if the previous owner has done the correct maintenance. Putting in the wrong oil can damage valves and rockers too. Do the research.
twincam nc
Prini said:
Selling the twincam? :fencelook:
No not yet:rollsmile:
Looks like i will have to be carefull for this one
But really liking it more and more
Will start with my research asap
Dont want to waste unnecessary money on a car that was not properly maintained
Thanks for heads up
Rayzor
Good luck with the purchase, they awesome cars if taken care off. I wouldn't suggest everyday usage :=):
eurotech
hi there
i have one and the nice thing abt them is that
yes brakes clutch etc are pricey to replace but they last long
if cared for properly.They are well built cars and maintained
through its life span will go a long way
Make sure the car has been serviced regular by a reputable person
make sure km's are correct
check brakes and disks,clutch etc
the one you get all depends on the budget dont compromise for like a 50k
difference between a clean one and one that needs work becuase you
will easily spend that money on repairing one thats not clean
good luck with finding a clean one,u more than welcome to come have a
look at mines so you no what to look out for
panose30
check for rear subframe failure,its common fail on e46 m3,if the year model is 2001-2003 check if the car makes the recall about the rod bearings.service history,regular oil change with 10-60 oil,also if its smg take care about fail smg pump(will cost 2000 euro to fix).
