BMW E36 Adjustable Rear Lower Camber Control Arm
alfate
Banned
Need to replace my control arm bushings and ball joint. That I found a Adjustable Rear Lower Camber Control Arm for my BMW E36, I think it's great!
The link: http://www.amazon.com/dp/B00RYGOGOE
This is introduction:
Fit For: E36 models; 3-series 92-98 (318i, 318is, 318ic, 323i, 323ic, 323is, 325i, 325is, 325ic, 328i, 328is, 328ic, M3), E46 models; 3-series 99-05 (323i, 323ci, 323cic, 325i, 325ci, 325cic, 325xi, 328i, 328ci, 328cic, 330i, 330ci, 330cic, 330xi, M3), E83 Models: X3 ¨C 2.5i, 2.5si, 3.0i, 3.0si ?through 2010, E85 & E86 Models: Z4 ¨C 2.5i, 2.5si, 3.0i, 3.0si, M-Coupe, M-Roadster, E89 Models: Z4 ?¨C 3oi, 35i, 35is 09-current
Adjustable Range: +- 3 Degree; Quantity: 1 pair (2 Pieces); Color: Black; Warranty: 1 year warranty for any manufacturing defect; Condition: Brand New
Made by high strength aluminum and durable Powder-Coated Finish, Improved suspension geometry to reduce bump steer, Improves Rear Suspension, Handling, Predictable Response and even Prevents Premature Tire Wearing, Design for Street, Track or Drift Racing Precise Adjustments with Long Service Life, Perfect for track cars, drift control, street course, off road, Direct bolt-on for OE factory or replacement
Professional Installer is Highly Recommended (No Instruction Included)
maXpeedingrods is also known as Maxspeedingrods
