Hi all
So I bought an e36 316i a bit impulsively, I needed a new daily driver and a friend of my parents was going overseas and was selling so I decided to go for it with the intention of driving the car a bit then selling it.
The car seemed to run fine initially but soon blew the head gasket l, I also started noticing some other issues with body work etc.
Anyway, I have decided to keep the car as my daily and slowly fix up the issues to get it running smoothly. So far maintenance has been 1x head gasket and head engineering (kind of wish I had gone for maybe a 1.8 motor for a bit more power-M42 I think, instead of fixing the head), new radiator and thermostat (trying to fix the overheating which was caused by the head gasket being clogged up), new starter motor, new bulbs for headlighs and brake light switch, new headliner to replace the gross sagging one that was on, I have also bought new brake pads which I will fit soon.
Anyway, now that the car is running reasonably well I wanted to start with some more fun things. Bought a set of style 44 rims which I will refurbish and then put on some 205/45 tires (square set up so I can rotate) and I also want to lower the front a bit just so the car doesn't have such bad reverse rake.
Now my main question is what front suspension setup would be easiest for me to get a slight drop in the front, is there any OEM setup for an e36 that is a bit lower than standard 316 which could fit easily? I want to retain driving comfort and just gain a slight drop in the front to even the look out and hopefully improve handling a bit. If there is no oem setup like this available my next option would be entry level drop springs and maybe having my current struts shortend? Although I would prefer oem.
Feel free to comment or chip in with regard to suspension setups that are budget. I will post pics as soon as I figure out how
