BMW 5 Series F10 Tuning Work, Wheel Stud Conversion Kit Problem
JhonMoon
Hello everyone.
I've ordered some aftermarket wheels, which I know the factory lugs aren't going to fit. Diameter of the head on the OEM bolts is too big. Knowing that I should purchase a set of longer bolts or convert to a wheel stud conversion kit.
In fact, I am going to order a set of stud conversion now because the bolts are becoming a pain to use without a pin.
I also did some study of them. There are several advantages:
1.They offer an easy way to align the wheel when mounting;
2.They allow for the safe use of different thickness wheel spacers;
3.It is compatible with both ball and conical seat lug nuts, which is suitable for most factory or aftermarket wheels.
(removed)
I am willing to buy a set of Titanium studs cause I learn that: "Titanium alloy materials, which possess high mechanical properties, not only have great fatigue strength and tensile strength performance but also maintain great strength at extreme temperatures up to 400 to 500°C. They are light in weight, also have extraordinary corrosion resistance."
P.S. These pics comes from Webs.
momo1
Welcome, looking forward to seeing the end result, before doing the stud conversion , make sure the PCD is actually 5X120.
find it weird that the lug nut opening would be smaller on an aftermarket wheel that is supposed to be designed for the car? is it intended for the Lumina SS perhaps?
NBN
you can use what they call is a tuner bolt, its usually much narrower and has an allen key insert to install and remove the bolt.
CA_130
Welcome, just note that you might not be able to adjust/access to handbrake mechanism using studs without removing the rear brake discs, so maybe just check them out before fitting it, adjustment is usually good for a few years or until you need to replace the shoes, worth saving you some ballache down the line doing it now.
