BMW 335i coupe – now with one turbo less
Ofentse
Guys, i was under the impression that 335i coupe was now replaced by the 435i, and that the former was no longer produced, but the article below seems to suggest there will be newer models entering the market... with one turbo missing. Is this article correct...?
http://www.evo.co.uk/bmw/3-series/6834/bmw-335i-coupe-review-price-specs-and-0-60-time
BMW 335i Coupe review - price, specs and 0-60 time
By Ollie Marriage|
2 Apr 2015
The twin turbo 335i has been updated, and lost a turbo. Does this signal the coupe's downfall?
It’s the BMW 335i coupe – now with one turbo less. I have a sneaky suspicion this move to a single blower is because future M models will be differentiated by being twin turbo. We already know the next M5 will use the X6M’s twin turbo V8 and BMW itself has confirmed that this M3 will be the last naturally aspirated model, the next boasting a turbo’d six. Anyway, that’s all for future discussion. The revamped 335i is part of a mid-life freshen up of the whole coupe and cabrio range.
Engine and performance
Most owners of existing 335i’s could easily feel shortchanged and go shopping elsewhere when told the replacement model has half the number of turbos, so BMW couldn’t afford to get this engine wrong. Nevertheless, BMW has bravely decided not to up the power and torque at all, but it has ensured the 295lb ft hit is now available earlier (at only 1200rpm!) and is still sustained until 5000rpm. Instead, the focus has been on improving economy (up eight per cent to 33.6mpg) and emissions (down ten per cent to 196g/km).
What’s it like to drive?
Let’s focus mainly on the engine here, because the only change to the suspension is the adoption of non-linear dampers (which do admittedly make a small, positive difference). But the engine is worth dwelling on, because what BMW has achieved is, frankly, baffling.
In the past we’ve marvelled at the twin turbo’s staggeringly rapid engine response, low end grunt and top end fizz and now BMW has bettered it in every area with a single turbo. It’s a variable vane unit, of course, but I’ve never driven a forced induction car so able to maximise both ends of the rev spectrum so well. There’s instant thump, not a hint of hollowness in the mid-range (even the twin turbo had a slight drop-off) and above 4500rpm, the 3.0-litre really opens up, the needle hurling itself at the 7000rpm redline, accompanied by a howling, M3-lite note.
It’s ultra-crisp, leaps forward on small inputs (especially in Sport mode, which also really pops home the shifts in the DCT double clutch gearbox) and the only time you hear the turbo is when you lift off, the high-pitched yip clearly audible from front right first, then left. Odd. Enough to have me lifting the bonnet, just to check that BMW hadn’t slipped in an extra blower. What they had done was written Twin Power Turbo on the cover. Let’s call it careful wording rather than deliberately misleading…
As for the driving, it seems to me that front end grip and poise is now slightly better and the 335i feels more planted, the suspension having tighter control of the body. The mods are just enough to make you feel there’s more edge to the 335i’s handling, but it’s the engine that’s the star of the show here.
Rivals
The Audi A5 is the BMW’s closest rival, but it doesn’t have an engine that can match the BMW’s blend of pace and economy. The 261bhp 3.2 FSI (£36,740 in manual S Line spec) falls short in both areas, while the £41,345 S5 coupe still uses the potent but thirsty 349bhp 4.2-litre V8. There’s also the Mercedes E-Class coupe, but Richard Porter, who runs our long termer, would be the first to admit that while undoubtedly a superior cruiser, it’s not exactly thrilling.
Anything else I need to know?
The bodywork’s been updated, although you’d be hard pushed to spot the new grill, lights, front air dam and rear valance. As a result it’s now 32mm longer overall. Couple of other things: if you want the seven speed double clutch DCT gearbox, that’s £1,640, and the lovely 19” wheels pictured here are another £520.
Price and release date
Prices start at 27,845 for the 320i Coupe, with the 335i available from £36,340. The M Sport tested here is £38,215.
Specifications
Engine In-line 6cyl, 2979cc, turbo
Max power 302bhp/5800rpm
Max torque 295lb ft/1200-5000rpm
0-60 5.4secs (claimed)
Top speed 155mph (limited)
On sale Now, for £38,215
Ofentse
thisISmyothercar said:
I think the date on this is wrong and the article is very old, you're looking at an E92
Yes i think the article is about an e92 production, it is dated 2 April 2015...that makes the article just 5 months old... hence my confusion :thinking:
harleyzx1400
The 335 has been replaced by the 435, beginning of 2014, I think, and it lost a turbo when the motors changed back in 2009 or 2010 from the N54 to the N55. Cheers.
Ofentse
:ty:
