Rays said:Hey guys,
Could you please give me some advice.
I would like to remove my catalytic converter and egr.
What are the pros and cons?
TIA. David
Sent from my SM-G930F using Tapatalk
Thanks for this Schalk.... I have had similar advice. Do you know if there is any trustworthy workshops to perform this? I am from cape town btw.schalk320d said:Rays said:Hey guys,
TIA. David
There are zero cons. The egr and cat are fitter to the car for emission regulations in European countries. Removing the cat would make the exhaust gasses cooler and as a result add to the longevity of the turbo,you might also score a bit of throttle response.
Blanking the EGR would not really have much of a performance advantage ,but it would definitely prevent build up in the EGR that could cause issues later on.
BadBoy23 said:who can help with this in Gauteng please
Solo Man said:Is yours manual or auto. The cat on the manual is easy to get out as the access to the turbo from below is not as difficult as it is on the auto. If you are handy with a spanner then it is an easy job. Egr delete is actually a two minute job but you need time to remove the egr and clean it as it is most probably clogged up with diesel gum. You should actually be more worried about getting your swirl flaps removed and the swindle holes plugged. At the same time clean the egr and just plug the vacuum pipe leading to it. Another very important item is getting the oil seperator out and remplacing it with the new style seperator that does not use the filter. I nowadays just remove the filter completely as i have found on my E60's that BMW did it already on some of these models.
Thanks. Had a look, who did you eventually go with?BMW CPT said:Did mine see my post BMW CPT. I would say clean intake and remove swirl flaps while at it. No real performance difference felt but qbout 8-1.5ltr per 100km lighter on fuel
Rays said:Thanks. Had a look, who did you eventually go with?BMW CPT said:Did mine see my post BMW CPT. I would say clean intake and remove swirl flaps while at it. No real performance difference felt but qbout 8-1.5ltr per 100km lighter on fuel
shark111 said:Gents on the LCI 320d, are the swirl flaps still problematic? I read about the issue being on the M47 so I thought I'd be safe. Apologies for the thread off topic!
Sent from my Mi MIX 2 using Tapatalk
Awesome thanks bud!schalk320d said:shark111 said:Gents on the LCI 320d, are the swirl flaps still problematic? I read about the issue being on the M47 so I thought I'd be safe. Apologies for the thread off topic!
The LCI 320d E90s don't have swirl flaps so you have nothing to worry about:thumbs:
