Battery discharging
pambaram
Hi Guys
I'm driving a 2012 E92 335. The car was parked in the yard and the doors were not locked ( I would say the doors were not locked for 30minutes ). When I inserted my key fob into the ignition a message popped up on my IDrive say battery is discharging. The car started perfectly fine with no errors after that
Is there any reason why this happened?
Lizzard
When you close the door, the interior lights will go off eventually if I recall correctly. Your car will still be on for about 15 minutes and then it will go into standby mode since you didnt lock your car I believe.
When you lock your car, the same thing will play off except that 15 min later the car will go into sleep mode and then wake up every hour for a quick scan of the car (which takes milliseconds)
Maybe a door or something wasnt closed properly and the dome light i.e. the interior light took a while to go off. Just see in the error codes section of your idrive if the car stored a code.
pambaram
Yes that's correct the interior lights do off eventually. Both doors and the boot was closed
FiRi@Rennzport
pambaram said:
Howsit Guys
I'm still having a problem where the battery is discharging
Any ideas why
Pra
Maybe get in touch with @ratslaaf and see if he can assist. his the boffin on these things. I would also take the car to a battery center and get them to test it and give a printed report to make sure it isn't the battery
FiRi@Rennzport
pambaram said:
Howsit Guys
Any ideas why
Pra
sash
pambaram said:
Howsit Guys
Any ideas why
Pra
With a new battery? If the car is still on plan make BMWs problem.
Kish2604
Administrator
pambaram said:
Howsit Guys
Any ideas why
Pra
Did you change the battery sinc least year and if so was it registered to the car?
Sent from my SM-G965F using Tapatalk
Kish2604
Administrator
Well you had a problem initially in the onset of winter last year and it has cropped up again this winter... My thinking is your battery is largely at fault here..
