Aux but no USB, will this kit give me USB?
QikNish
Doubt it. OEM retrofit requires programming at dealer to work. Im sure this would need also?? Can't be simply plug and play - i dont see any "control boxes" in the pics.
OEM retrofit kit about R2.5k i believe + programming costs.
Spook
I would be interested in this as well.
Definitely miss the USB input.
I would appreciate it if you could give some feedback on your findings.
Regards,
Sugen.
HellfireZA
I know there is some coding that needs to be done from reading around.
Well just got a price from SMG Cape Town @ R3061 inc vat for the kit. Not bad considering the cheapest I've seen online is $450.
MattyEMD
it looks like this.
unfortunately i have to bring in volume to get better pricing so they expensive R300
or i can get this
like a normal flash with the aux in the back.
about R165 incl vat
S1NGH 911
Not gonna work, you'd need a USB capable MULF, then need to get it coded AFAIK.....
Sent from a tikkie box using Tapatalk
MattyEMD
Nope, the dongle is the USB Bluetooth adapter, the hole in the end takes a 3.5mm male to male cable. One in the USB dongle, one in the aux port. Allowing you to stream music to the dongle via Bluetooth to the aux port. I'm doing it in my car
michaelniszl
I'm sure he is referring to the OP's question :=):
Bugger
MattyEMD said:
it looks like this.
or i can get this
about R165 incl vat
As far as the R300 unit is concerned, how does it all connect up? I currently run an AUX cable from in my arm rest and then put my phone on the top of the ashtray, so would be interested in something I could hide away and neaten it all up a bit. And that unit looks the business.
