assistance please gents
reid
hi guys,
any idea where i can have my right rear light bulb replaced. bear in mind it isnt the break light per se, but the normal running light is very dim.
would take her into the dealership but id have to go through removing DP and exhaust :(
thanks
akash
I dont understand.
Is the bulb you need to replace in the tail light cluster?
If yes, then that very easy to change and there should be enough DIY instructions online.
reid
akash said:
I dont understand.
the bulb
reid
yeah the right tail light is dimmer than the left so im assuming it needs changing bud- bear in mind it isnt the break light
akash
Then that should be easy enough to change.
There should be a few DIY's floating around on the web.
BMW wanted my car in for the whole day just to change the bulb. I did the change myself on both my E90's
M135i
You think they would notice the downpipe?
Considering they wouldn't put the car on the lift to change the bulb?
Only tell tale sign I guess would be the noise level...
But yeah rather don't risk it
From what I have read on the net, you open the boot, remove a bolt holding the light cluster in place, pull the light cluster out revealing the bulbs, then replace the needed bulb
