Another M135i fitted with JB4
Sherwin@xcede
DVST8 & I setup Andz car & had some good results. Here's a video of the power after, just JB4 with eth, it ended up making 280 kw on wheels up here at altitude & 622NM on the wheels:
[video=youtube]
c0mrade
[video=youtube]
hi guy's thats very impressive ,is this an auto ?
and what map are you guy's using and what ratio of eth ? :thumbs:
Sherwin@xcede
95 pump fuel should be about 10kw less. So around 270, maybe 265. Hard to say. We will do a dyno on pump fuel & see.
AshG108
Hi gents, this is indeed mad power. Is this a 2014 model and if so, they have more power than the others?
is this true?
Quick///M
is this true?
Not sure if that is true my car stock at kar dyno'd 216wkw but 210wkw + is the norm for these cars
c0mrade
sorry bud is this car a auto ?:thumbs:
IC3
Amazing gains. Well done to all involved.:praise:
Hi guys, slightly off topic
But wanted some input from Sherwin or other members familiar with JB.
How easy/difficult is it to remove the jb4, as I understand it doesnt plug into the OBD port but into the ecu directly.
Reason being is, I would like to remove the JB4 if I fit it , example : when I need to take the car in for service etc.
Not looking for major mods, just Stage 1 is enough for now. You can PM me if you prefer.
Thank you
PS Im in Durban.
dvst8
Thank you
PS Im in Durban.
Hi, it's not difficult at all. With the F series it's actually easier than the E series.
It's does not plug into the ecu at all.
2 or 3 sensors, power and ground. There are 2 wires that tap into the CAN wires but that is simple to install and remove.
On an E series, I would say about 30 mins to install/remove. On a F series about 15 mins.
Once you used to the installation and removal, you can do it much quicker.
:thumbs:
