Another E90 Battery Replacement Question. Why so many confusing answers?
DeanoBlado
Hi guys
So yesterday i went to our local mall and upon returning after about 4 hours the car didn't want to start. Did a voltage test and it showed 11v, anyway long story short got the car up and running.
Did a battery test this morning at my local battery centre and their machine indicated i need to replace my battery.
I still have the original battery which is almost 8 years old. 12v 80AH 640A is written on the battery.
BMW wants R2559 to replace? still looking at options
My question is, will this just be a straight swop? the guy i spoke to at BMW said yes. My model does not require a reset. The forum is 50/50 on this. so which one is it?
Thanks guys.
DeanoBlado said:
Hi guys
Thanks guys.
Been down this road
Depending on your year model of your car , it may or may not come with IBS(not the one u thinking off-lol)if it does, then your battery will have to be registered to the car.
If not-straight swop, obviously making sure that your alternator is 100% during thr battery load test.
My alternator failed after my new battery install. Battery light never went off.
Sent from my LG-M400 using Tapatalk
DeanoBlado
Deon Rupnarain said:
Been down this road
Thanks, do we know which models have IBS? why is this such a grey area.
After starting the car the voltage showed 14+- volts, meaning alternator is charging?
Been down this road
I would think any car after 2010 ...i could be wrong cause i only researched mine.
Yip your alternator is 100z.
Yuben
Senior Moderator
Mine was a 2006 model and the battery required registering due to the alternator being used to working with lower voltage of the ageing battery and could not self rectify after the new battery was installed.
My advice is whether your car has IBS or not, it can't harm to get is registered anyway.:dunnoanymore:
The harm is felt when agents tell you R1400 or something to register.
Which is balls.
Mine also 2006.
NtandoN
Get it registered. Mine doesn't have IBS and the battery didn't last when it was not registered.
Registration cost is R500 and BMW battery is R1950.
Yuben
Senior Moderator
Which is balls.
Mine also 2006.
Find someone with INPA, if a forum member can assist, it can be done for free
Yuben
Senior Moderator
If you near the West Rand, contact JR, 082 817 6048, he will be able to assist:thumbs:
Which is balls.
Mine also 2006.
Bmw pinetown are overly charging ....they mad.
sash
@deanoblado, which are the confusing answers? where are there so many?
I only see 2 options, if car has IBS reset is a must, if not, its optional
DeanoBlado
What i meant was if you search on the topic even on this forum, there is not a clear cut answer like you put it above. How do you know if your car has IBS?
Anyway its sorted now, i just got back from BMW and they had to reset it. Replaced with the exact same battery that was removed. costed me R2098.
hoping for another 8 years before it dies.
Thanks guys for offering to assist with the reset.
Ratslaaf
Guys, IBS or not, the car needs to be told that the battery has been changed. As batteries age, the alternator changes the way it charges the battery in order to get the most life out of it.
Then clearly BMW ptn needs awake up call . their technicians are asses!!!!
They told me , my car doesnt have IBS and my alternator is cooked so i dont have register bugger all.
Yuben
Senior Moderator
Fully agree @Ratslaaf
SubLoaded
Resident Derailer
I've referred Deon Rupnarain to someone in Durban. Not sure if the car has been checked out as yet though :hammerhead:
sash
You learn something new everyday, here i thought the IBS was the intelligient part in the newer cars, seems our older cars also have some tech.
Hey man . the car is sorted . brand new alternator purchased as registering the battery didn't make a difference(that was the first thing we tried) , your contact is blady brilliant ....the entire car has been updated via the BMW software he provoded. . I am so pleased , car is still a pleasure to drive.
Thanks bru.
SubLoaded
Resident Derailer
Thanks bru.
No worries, glad to hear that your problem is solved. He's spot on when it comes to these cars :praise:
