Advice Needed - Engine Fault Warning Popped Up
Aadz17
Hey Guys
So yesterday I was driving my car, E92 335i 70/30 between spirited driving and cruising when an the engine fault warning light popped up, with the reduced power message.
I know the car will reduce power if it feels the engine is in danger, however the car didn't actually lose power and felt like it was running normal. I drove cautiously for a while, pulled into a parking lot and left the car idling for a while, thereafter switched the car off and started it again and the error message was gone. Has something similar happened to any of the forum members or could some one advise me on what has happened. Could it just have being heatstroke or something more serious, (Vanos Solenoids, HPFP, Injectors)
Just for FYI purposes the car has 54 xxx kms on the clock, if I can remember correctly the temp was sitting between 100 to 120 which is the norm.
If you have k+dcan cable or can borrow one and android phone you can read codes for free with MHD app
Sent from my HUAWEI GRA-L09 using Tapatalk
Aadz17
[quote='"]
[/quote]
Dont have that cable, will need to borrow one or buy.. :skit:
Woodies
Yeah only way is to check fault codes, could be a million things or nothing. My n54 did this a few times. I cleared faults and I haven't seen it again. Reduced power normal just kills the boost mostly.
These n54 are amazing but temperamental.
Aadz17
Any fanatics in or around the Lenasia area that might have the k+dcan cable that I can borrow?? [SEE-NO-EVIL MONKEY][SEE-NO-EVIL MONKEY]
Sent from my ALE-L21 using Tapatalk
Iceman12596
I have the same sh1t with my N54 also, i do exactly the same turn off and then on and bada bing bada boom its gone, happens from time to time.
Going to go to Douglas from D-Tec to have him scan the car for any faults, he has some diagnostic machine that is on steroids LOL :roflol:
Aadz17
Yeah I think I'm going to have to do the same thing just need to find a good mech/ fellow forum member close to the Lenasia area, wouldn't want to drive to far with the car in that state
akash
The car goes into limp mode when something is out of tolerance. One does not own a 335i without experiencing limp mode.
Check the error codes and take it from there.
Iceman12596
akash said:
The car limp go into limp mode when something is out of tolerance. One does not own a 335i without experiencing limp mode.............SOOOOOO TRUE !!! LOL
Aadz17
Lol I know I was bracing for it sooner or later just hoping it would have being later
Thaves
had the same issue with mine but couldnt pick up any error codes, it wouldnt lose power but the last time it did, the turbo cut out. i have since changed the battery and have not had the issue since. goodluck bud
NFCKN'SANE
The Warnings are quite Dramatic both the Tire Pressure loss and heart stooping caution Triangle.
I suggest have the car scanned for codes, Mine random throws up the error as well, Codes say its the O2 sensor - I have had it cleared and check and every time its the O2 sensor.
One of many possibilities I guess..
Aadz17
That's interesting, that the change of battery sorted the issue out for you will take that into consideration
Aadz17
So gents I did a a diagnosis on my car. The error is loss of boost, a 30FF code. :smashScreen::thumbdo:
What would be the next step in order to sort this problem out and who would you guys recommend to sort this issue out?
I would also like to know how costly the repairs could be??
Check for boost leaks. Check the charge pipe and intercooler connections for leaks. Also check vacuum lines. Clear the code and see if it comes back
Iceman12596
Does the car have the original DV's in.......if so i would check those, cause they perish over time, i have a sneaky suspicion mine are gonna give up the ghost i got a set of Forge DV's.........im just to much of a laygat to install em LOL.
Aadz17
[/quote]
[/quote]
Yes it still has the original DVs... How are the forge DVs compared to the OEM DVs??
Iceman12596
[/quote]
[/quote]
Will let you know when I fit em.
Afaik they are much better in terms of holding boost better and it also gives piece of mind know owing you got the good stuff in your chariot
Aadz17
Thanks iceman .... I look forward to hearing about the forge DVs.... Who would you recommend for a good mech especially to work on these N54s
