ABS light on start up
blaze94
So i removed my air con unit and obc out of the e36 over the weekend and this morning replaced everything. On first ignition the ABS light came on and then went straight off. I work just round the corner so after i shut my car i quickly started it again to see if it was justa glitch but it happened again. ABS control module stuffed?
This is for a 98 318iS E36
blaze94
Quick update, started the car at lunch time to go and get some super 14 tickets and again the ABS light flashed. 5pm when i started the car to go home nothing, no flash.
Weird.
zaleonardz
Prob a wheel sensor that is starting to go, but get it onto a diagnostics machine so that it can tell you.
blaze94
Just went and started it now, everything perfect.
I'll leave it for now and see what happens, maybe hook up a multimeter over the weekend. I work so close to where i live that i have a 5 minute commute through a residential estate, just enough time to get the temperate into the clear.
