At least you got the wife cleaning! :mmm:
BTW, I got those grilles fitting perfectly. When I was swapping my headlight inners back to the black ones I found a bracket that was pushing on the back of the passenger side kidney grill causing it to not sit flush, just bent the bracket away and taadaa. The trick is to NOT separate the two pieces so I put some Q-bond on the clips.
I also bust out the airbrush, mixed a tiny bit of paint and airbrushed the rusting stone chips after I sanded them down with 1200grit paper. The front looks flawless now, will post pics soon...
