850 rear strip down and rebuild
The Meatman
Great going Luis, keep it up. you seem to have the energy and motivation to sort it out for the next 30 years. I like the colour of your car. I have nightmares just looking at all the rusted parts. Went thru the same mess. and resprayed mine with Hammerite. BMW did not do a great job in the assembly line originally when these cars were built as far as rust is concerned. Seems to be a common problem with the cars.
Luis Malhou
Thanks Meatman. Yes been quite an ordeal but almost done and then it will be great.
When ever I do something like this I always prefer to go beyond, in the long run rather take time preparing and stripping as much as possible. Powder-coat and nickel or galavanise as much as you can. In the long run its very beneficial.
Luis Malhou
So I love this part when pieces start arriving for re-assembly from the sandblasters and powder coaters.
So nice to get lovely new shiny bits and pieces..
Luis Malhou
So the fuel tank is back in, some fuel lines connected.
See the difference between the before and after picture of the bumper brackets. This shows what a differance all this work will eventually lead too.
Main suspension part comes back from the galvanisers today then the real re-assembly will start.
Luis Malhou
So some late night work on Friday left me with side shafts done, what a pain to get 6 steel balls into their respective chambers, and do it 4 times.. @#$$
Anyway they done, new seal and o-rings fitted to the diff shafts and re-assembled. Now I can finish cleaning the diff and paint.
Wheel bearings re-inserted and then I pushed in the shafts only to forget the brake backing plates. So pressed the hubs off again this morning and will re-assemble today. Pain when you forget a step!!
All the plastic clips and fittings cleaned and now the sensor cables were next for a good spring clean.
So looking good to have her on the ground by end of Sunday.
Will only need to wait for the new handbrake cable.
anton-sa
awesomne work Luis!
my e28 recently also saw some of its suspension components and the bash plate getting some powder coating treatment. its what i like to call a OEM+ upgrade :)
:thumbs:
The Meatman
Luis Malhou said:
850 REAR STRIP DOWN
The 850 is now parked after the last Breakfast run on Sunday and the long overdue rear end is coning off.
The unflattering waddle and rear end rattles will be coming to an end. Jacked the car in the air last night and will be doing a thread on the following work.
1. Remove the complete rear end suspension.
2. Rear brake system to be removed ,
3. Remove rear bumper and all parts
4. Fuel Tank and all pipes to be removed
5. Diff and side shafts removal
6. Under carriage clean up and remove and treat any bare or damaged areas and rust treat.
7. All rear suspension bushes removal and replace (18 in total. all new OEM from BMW) already arrived
8. All suspension parts to be sandblasted and powder coated or sprayed with Poly Urethane paints
9. New fuel lines
10. Tank cleaned inside and outside, new hoses and clamps
11.. Bolts an nuts replaced or electro Nickel Plated
12. Bumper parts sandblasted and powder coated or Poly sprayed.
13. New bilsteins sports shocks installed, redo rear coils, re-temper the coils to original compression strength
14. New Brake lines
15. Diff serviced, cleaned and sprayed
16. Side shafts overhauled,
17. Re-assemble and look forward to a excellent new ride and feel!!
This going to be long job but once done, the car will be one of a few 850 that have been rebuilt from front to back and be clean!!
Have a look at my "re-do on the thread under my post
Luis Malhou said:
850 REAR STRIP DOWN
9. New fuel lines
14. New Brake lines
Luis Malhou
Actually forgot to update..
Re-assmebled and it drives like a dream. No more fuel problem issues and I know its all clean under there.
After the build we took it to Angelas Picnic, bronkhorstspruit and back to the Vaal with not one issue and an average consumption of 12.5lt/100km
The next thing to be done is the removing of the calipers, they will be sandblasted, recoated, rebuilt and installed together with new brake hoses and pipes. That I will be sending to a specialist. After storing some cash I will be doing the leather and the respray.
The Meatman
Brilliant job, looks better than new. Well done. Nice to see.
Luis Malhou
Forgot to add. THE EXHAUST IS THE NEXT THING TO GO!!! Terrible what the previous owner had done, never mind he called himself a connoisseur of cars!!!
The Meatman
if i may make a suggstion, Powerflo did mine in S/S and they did a brilliant job. that tried 2-3 mufflers until i liked the sound and only charged me for what was finally installed. These guys also seem to have the best configuration for the exhaust system. What the did was to go with the last configuration of the 4.0l motor as standard in the 540i and 740i before BMW went to the 4.4l as standard. I had mine finally chipped by Koos Swanepoel Racing Developments in Stikland with a DASTEK Uni-Chip. Gave me about 8% more Kw and Nm. But the mapping made a massive difference to town driving and the torque band kicks in a lot lower making for a lovely town drive..
Luis Malhou
I am looking at taking it to Powerflow in Edenvale. heard good things about them. Its also down the road of the brakes guy. Star Brakes if I remember.
Meatman, can you send me details of the guys you mentioned did the interior. PM please.
Thanks for everyone's comment
:thumbs:
