540 altenator
Maljan
If a dead alternator can stop a 325i, it will stop a 540i. Don't ask. :cry:
Anyways, with the battery not being charged it is only a matter of time before there is not enough volts and amps to power the computers, spark plugs, fuel pumps and what not.
Fordkoppie
Depends on what you mean.
If the engine was doing 6000rpm and then suddenly stopped, the alternator would have very little to do with it.
However, if it slowly deteriorates, the low voltage might be the big issue.
Describe symptoms in detail....... What you are asking can only be seen in a crystal ball
Straight six
If your battery is not being charged by a "dead" alternator.....
Over time even a 16 cylinder quad turbo will die...lack of voltage supply
jas.vanwyk.7
Remove the alternator and the back bering isolator disintegrated . Found this out after the engine came to a sudden stop on idle. Just thought that it is hard to believe that a v8 can be stoped by a alternator. Is it posable?
Maljan
That mighty V8 burns petrol to propel the car. It is pumped from the tank to engine with an electric fuel pump. The fuel is ignited by electric spark plugs. This process is controlled by an engine management computer, which uses electricity. The mighty V8 puts its power to the road through a gearbox. If this is an automatic 540i, there is another computer that tells it when to shift gears. This is also powered by electricity. There are lots of other things in the car that uses electricity but the above are the most important ones involved in keeping it mobile.
The alternator also charges the battery while the car is mobile, but that is not its only function. It converts petrol into electric energy, of which modern cars need quite a lot. The electricity in the car comes mostly from the alternator when it is running. The battery takes up a bit of the slack, but it is mostly there to get the engine started. Or so you can listen to the radio while you clean the interior.
When said alternator stops working, a little red picture of a battery appears on the dashboard. Or is supposed to, anyway. If this did not happen, you may have other issues as well. In this state, the electricity comes from the battery only. It is only a matter of time before it goes flat and the mighty V8 comes to a halt.
jas.vanwyk.7
If the bering holder at the back of the water cooled alternator disintegrate , the alternator armature catches the side of the alternator and causes a huge amount of friction , but that friction is it enough to stop the v8 engine or is there something els except the current loss that stop the engine
