525I not responding to the key after draining the battry
Godfather1auto
hello good people.i have a 525i that is giving me headache after draining the battery it does not want to start.its not responding to the key .I have checked all the fuses and all are fine.does any1 know if there is a way of working the car after it shuts itself due to low battery power
Stephanv
I dont know if you tube might help. But in my Audi it did the same. How to fix it.. Insert the key in the ignition. And turn it to the aux on position. While turning it press and hold the lock and unlock buttons.
This re synced mine. But im sure BMW might be different. Like i said YouTube might have more answers.
Godfather1auto
Eish the issue here now is the car has a push to start button and a key that is pushed into the fob which then initializes the system.its not even doing that thing of sucking in the key.
individj
with teh older models theres a sequence you do with buttons to get it to sync check teh tubes.
