Shuaib1
Hi guys
So as I'm about to go home and start the car,put the key in and all the lights come up as usual, the car doesn't start
thought OK might be the earth running to the motor so I put jumper cables from the car body to the motor and still no luck. When I press the button I'm just getting a tick sound. What could it be, starter or battery? Will try and swop the battery later to see if it helps. Got the car towed home but I just want to check the battery first. Otherwise I will book the car in to be inspected.
Thanks in advance
Thanks in advance
