335i Engine smell
Maximus03
Hi Guys,
Just want to know if it is common to get a burning/funny smell from the engine after a normal/slightly hard drive? Temperature got to about 120 but the car always has a weird smell after when parked and switched off.
Is it normal?
Maximus03
frikkieh said:
Beat me to it :bravo:
Are you sure it originates from the motor?
Thanks hoosain,
Well its hard to tell exactly but it is pretty hot too, even the plastic parts in the engine bay.
It may be the brakes, but do they smell for over 45mins after parking?
Twinz
Forum - Support
That does not "smell" right. Check everything under the hood for oil or even fuel...take the cover off the motor and check if you can see obvious wetness or smells such as oil or fuel and try & locate it. You should be able to pick up unusual smells even when the car is cold.
Maximus03
It smells hot, not an oil or petrol smell as such. More a dry pungent sort of smell, maybe it could be the cats?
Im new to this and got the car for less than a month now :rollsmile:
J
Josh-ZN
gecko went in to stay warm at night when i got home and got fried after some spirited driving the next day :rollsmile:
it happened to me a few months ago.
Twinz
Forum - Support
335 runs hot after hard driving and the heat will linger for awhile after switching off the car. Well modded 335s run cooler. Is the car stock?
Maximus03
Car is still stock, for now :rollsmile:
