330d Rough gear changing
Duvalle
Hi. I have an E90, 330D AUTO. The gear changing gets rough at times ... the gears take long to change and when it does it is not always smooth. This happens in both Normal and Sport. Recently there is a "Burning" smell coming from the car.
I guess that the gear-box needs to be replaced ...
Any suggestions please? Tx
Nikhil
Reset gearbox adaptions. the burning smell sounds like a pulley issue or a belt slipping
Arbee
Crankshaft Dampner Pulley on its way out bud... drive the car very slow to your nearest mechanic/bmw and let them replace it. I had the same issue... costed around 8k at Tune Tech.
Sent from my GT-I9500
Andy1GP
Clutch Delay valve, auto = no clutch :thumbs:
Arbee is right about the vibr damnpener. It's a costly part and very tedious to replace.
Philip Foglar
With the burning smell, +1 for the vibration dampener pulley as said above. Let us know if the gearbox returns to being smooth after resetting the gearbox adaptations. :thumbs:
Duvalle
Thank you all for the replys. I took the car to the mechanic today ... You wouldnt believe this ... There was a piece of plastic burning on the Exhaust, causing the 'burning smell'.
I will feedback once I reset the gearbox adaptations. Is there some a good place I can go to in JHB for this?
