320i E90 headlights
levy
Hi Guys,
my 320i E90 headlights don't wanna lift-up when i start the car.
at times you can hear they trying to lift-up but they end up failing.
so they not lighting up the road as far as they should.
Dim and brights are normal.
Please help:fencelook:
Kyle
levy said:
Hi Guys,
Try something heavy in the boot.
levy
KyleNaidoo said:
levy said:
Hi Guys,
:roflol:
heavy?
akash
You can adjust the headlights manually.
There is a plastic hexagonal nut behind the headlight. You can see it when you open the bonnet. Should be white in colour. Adjusting the nut will lower or pick up the beam.
Im assuming you have halogan head lights
Krin
levy said:
KyleNaidoo said:
levy said:
Hi Guys,
:roflol:
heavy?
Kyle may have a point there :idea:
My A4 (B7) has sensors on the rear suspension that the car uses to automatically adjust the level of the headlights. I think the same may apply to the E90?
Kish2604
Administrator
check that the sensors on your front left control arms and rear control arm are still attached, however if the headlights do not cycle up and down when first turning them on then the little servo motor has either failed or disconnected itself. I had the issue where the ball on the servo disconnected itself from the reflector, it was a small job of opening the bumper lining and clipping of the bumper to remove the headlight. after that it was 5 min to slot it back in and all was normal.
Kyle
Krin said:
levy said:
KyleNaidoo said:
levy said:
Hi Guys,
:roflol:
heavy?
Dunno, was being sarcastic.
D
Dippies
MariusH said:
Don't know if you guys saw the e-tolls case on carte blanche http://carteblanche.dstv.com/player/439984 :bangdesk::argh:
:thumbs:
levy
Hi guys, I found that the sensor on the front left cntrl arm was loose.
i clipped it back but still no vertical lift. But, they kinda trying to lift a little but give up.
i'll look up on the rear wheel today. :argh:
Im not that mechanically clued up and i almost kicked the front bumper cos i tried and failed to remove the whole headlight. :cry:
