Rambam
Hi fellow fanatics.
Before I dive into the DIY Dual Vanos seal replacement next week just want to check for any other opinions. My car recently started hunting between 500 and 1800 RPM when engaging the clutch. This compounded with the bit of extra juice the power streering pump pulls from the engine when turning causes stalls at often undersired times. It's been getting worse gradually and now I think it is time. Cold starting is not an issue and the performance is still acceptable. I have had her 3 and half years now and dont think the seals have been replaced before. I've checked for vacuum leaks, so dont think its that and plugs are new cause I recently serviced her. MAF was also cleaned. any other possible causes? I guess the vanos seals is a good thing to do anyway?
thanks!
thanks!
