1997 BMW 316i E36 Not Starting
Saberhunter
Hi Guys, i dont know if this is the right place to post, I was driving my car yesterday and i stopped at the garage to put in petrol, but when i tried to start it again it wouldn't start.
things ive cheched:
fuel pump is working
no power going to fuel pump
fuse 18 is good
fuel pump and dme relays are good.
please help:blueCry:
Saberhunter
i didn't check for spark, but i'm not getting power to the fuel pump.
The guy is coming by today to do the diagnostics test.
Hopefully its not something big. i checked the Crank Position Sensor and its full of oil and hardened dirt, so hopefully it's only that. I'll keep you posted.
geezmo786
If you need one hola at me if you in CPT :)
Saberhunter
Okay, so i had the car at EMI auto in Rustenburg, the guy says that the diagnostics didn't pick up anything. they manually cheked the car and he says it doesn't get power to the fuel pump, no power to injectors and no spark. he says it could be faulty wiring going to the computer box or the box itself. how do i even begin testing it?:hammerhead:
motronic guy
Stuck open evap solonoid, its causing morethan needed reach mixture in the combustion chamber, after adding fuel from the garage, fuel fumes due to higher pressure from the tank, pass straight to the combustion chamber through computer controlled, stuck open, evap solnoid..try disconnecting evap solonoid,block vacuum leak from solonoid, press pedal fully and try to start...other cause might be pressure sensor n the tank..
things ive cheched:
fuse 18 is good
Have you checked with a volt meter/light tester that there's power at the dme and fuel relay harness?
Sent from Cape Town
francoishensen11 said:
things ive cheched:
fuse 18 is good
Sent from Cape Town
If there no power at the relay wires it's likely the 'crash sensor' popped it's located in your boot, the thin positive wire running from the battery, trace that wire, the fuse will be wrapped and you'll have to slit the cable open, it will be aprox a meter or less from the positive terminal itself, if you trace the cable, you'll feel the fuse within it, the dme and fuel relay gets its power from that cable, if it's popped you won't have spark, fuel or injection pulse but first check for power at the relay harness before going that route, keep us posted [SMILING FACE WITH SMILING EYES]
Sent from Cape Town
see the thin red one, trace it, that fuse is in it.
Sent from Cape Town
