15MM WHEEL SPACERS
vishal@somaitech
HEY GUYS,
I HAVE A SET OF 15MM WHEEL SPACERS FOR BMW E90 OR SIMILAR FOR SALE. THEY ARE FOR A 72.5MM HUB DIAMETER WITH 5 HOLES ON A 120MM PCD. MACHINED WITH PERFECTION FROM 6082 ALUMINIUM AND VERY TIGHT TOLERANCES. THE PRICE IS R550 FOR THE PAIR. PLEASE LET ME KNOW IF YOU ARE INTERESTED.
Gizmo
Banned
vsomai said:
HEY GUYS,
I will take them. You have PM.
Twinz
Forum - Support
Gizmo, when you have time show some before and after shots.
Spacers do make a difference in handling too....but one has to take the right size...too wide and the effect is off...the perfect "flush" wheel arch look is the ideal.:thumbs:
I have also noticed that the spacer width for improving handling is not really so dramatic as the look. In other words you can get the same handling improvement on a 5mm spacer as with a 15mm spacer but you wont get the "flush" and cool look as with the wider 15mm...enjoy :thumbs:
vishal@somaitech
andrewbuch said:
How safe are wheel spacers??
the spacres are hubcentric and as long as the wheel is balanced and runs true on the hub then there will be no vibration and therefore be safe. handling is much much better. i had to go 18mm on the back to get a flush alignment with the outside of the rear fender.
my bolts are M12 x 1.5 x 40mm long, which is also safe as there is enough thread engaged into the disk.
