Hey fanatics. I know that the 125i has a 3l motor but I'm curious to know what the differences between this motor and the 130i motor are? Are there any hardware differences or is it just software?
Maybe also the intake manifold - 130i/330i has the three stage intake, could be that the 125i (same 3.0l engine) has different software as well as the two stage intake. Basically like the E46 engines with a single DISA flap whereas the 130i/330i has two DISA flaps...
The 130i and 125i engines according to what i was told. The difference is the software with the 125i being detuned. You can get the 195kw if you do an aftermarket tune i am sure and hece the 130i performamce:thumbs:
I've read on the Z4 2.0 2.3 2.5 and 3.0 All Differing in compression ratio, so I suspect different cam's and tunes as well, valves possibly too. Google will help you out :thumbs:
