Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
30d - 40d/50d conversion
#1
Hi Guys
Forgive my technical ignorance but has anyone tried to convert their 30d into a 40d or even better a 50d?
From the info I have found thus far the 30d, 40d & 50d are all the same engines (N57D30) but each has a different turbo? The 30d has a single turbo whilst the 40d has a twin-turbo and 50d a tri-turbo.
[Image: da27cb3d239746cc0fb7fb67321795c4.png]
Wondering if it would be possible to buy some x5 40d or 50d OEM parts (either new or rebuilt) and put them on my 2013 x3 30d (F25) (which also has the same N57D30 engine) to make this a 40/50d then do a straight pipe with software for some serious power. Assume there would be other mods required as well but from what I have found thus far biggest difference is the turbo?
Have been wanting to do the straight pipe, Dp, DPF & EGR removal with a stage 2 software in any event so this might be a crazy but worthwhile initial purchase to prevent duplicate purchases at a later stage…
*Yes Lockdown has me very board and dreaming
Came across the following article on Speed hunters but this guy did an engine swop, I’m looking at possible OEM differences between 30d, 40d & 50d as the x3 only came out in a 20d & 30d in SA.
http://www.speedhunters.com/2016/03/bmw-...ple-turbo/
I call her Oprah as she's a torque show
[Image: grey%20line%20m_1862707798.jpg]
Current: x3 F25 30D M Sport
Current: Mazda RX7 FD
Ex: 1 series 125i Coupe
Ex: Polo 1.9TDI Sportline (The one that got away)
Reply
#2
I cant comment technically but would imagine the 30D & 40D are very close...think its intake and turbo....M50D i think will have much more difference.
there was a swopped 1 series in Speed & Sound...140D...swopped from a 6 series i think.
CURRENT: BMW E36 M3 Coupe PROJECT...plan.. 18" EwingEquips & TURBO
CURRENT: BMW 330i individual..Arizona Sun on 19's
CURRENT: DATSUN PB210 aka BIN aka "Z" Coupe 2L on EwingEmotions
CURRENT: AUDI A5 on 20" Concavos
CURRENT: Rothmans VFR400 NC30 PROJECT
CURRENT: Repsol VFR400 NC30 PROJECT
EX: BMW 330i, BMW 330i, Range Rover 4.6 HSE Vogue, FORD XR6 & RS Turbo, OPEL Monza 200iCD16V, Toyota GLi Exec, VTEC, ALFA Giulietta & GT Junior stepnose, a few mingers
The following 1 user Likes individj's post:
  • mathias
Reply
#3
single larger turbo on a 3.0d is probably the most economical path. Has been done, and from what I hear power figures are good
#NoLivesMatter
The following 1 user Likes tman's post:
  • mathias
Reply
#4
(20-05-2020, 07:52 PM)tman Wrote: single larger turbo on a 3.0d is probably the most economical path. Has been done, and from what I hear power figures are good
This is the correct answer. It is not a cheap exercise, but a few guys have done it on their 30d and achieve around 330kw and 800nm+. RK and Madness have cars that have done this.
The following 2 users Like billionairebum's post:
  • AshG108, mathias
Reply
#5
(20-05-2020, 03:42 PM)individj Wrote: I cant comment technically but would imagine the 30D & 40D are very close...think its intake and turbo....M50D i think will have much more difference.
O wow, thanks for bringing this to my attention it was a great read... the 140d is an absolute beast but has a lot more done to it over and above the engine swop.
Here is the link for those of you which haven't read it https://www.speedandsound.co.za/smoke-fa...ers-dream/
Thanks Gents, have been following Madness for awhile so I'm aware of the bigger single turbo option but this comes with other issues, was hoping for a "simpler" OEM option...
My thinking is that BMW would have done their research and opted for the various turbo options for a reason as I will be using the car as a everyday drive, then there is the fact that these OEM parts are readily available both new and used.
Will do some further research on the OEM 40d/50d parts otherwise the bigger single turbo option will definitely be a feasible option.
Reply
#6
A 40d has different internals to a 30d as well. But you can get the performance of a 40d with a simple stage 1 flash on a 30d.
Reply
#7
(21-05-2020, 11:37 AM)Bazza Wrote: A 40d has different internals to a 30d as well. But you can get the performance of a 40d with a simple stage 1 flash on a 30d.
Can you refer us to a source to confirm? The document attached says all three are N57D30 engines with only the number of turbochargers used, as the difference. I would assume if the internals are different, the N57D30 number will be different .i.e N57D30XX or something  Fencelook
Cartel
Current:
2014 F30 320d with M performance power kit : My run around
2019 G05 X5 xdrive 30d M Sport : Family wagon
2019 G20 330i M Sport : Hers
Ex:
2011 C350 CDI
Reply
#8
To get a comprehensive list of differing parts between the 30d and a 50d one would need to browse realoem for p/n and compare. At the top of my mind would be injectors, turbocharger/s, piping for the same, probably a bigger cooler from factory to handle the volumes being dispensed by the tri-turbo setup, a different ecu to control the 3 turbos, possible intake manifold differences, different radiator and oil cooler, definitely a different gearbox to handle the additional torque (it would still be a ZF but a different model in the family) and so on...
it is definitely possible but only with a large wad of cash, some diy and electronics understanding as well.
Current: Danger Ranger
Ex E92 335i DCT
400m @ 11.516 @ 203kmh
Backed up at MSA event!
60-130mph - 8.3 seconds
Dragtimes.com
Time is the best teacher.. Unfortunately it kills all its students Bangdesk
The following 1 user Likes Kish2604's post:
  • mathias
Reply
#9
@Kish2604 is correct, from the F15 line, 30d engine code is N57N, 40d is N57Z and 50d is N57X, with the 50d using a different piston and rod according to part numbers at the very least, along with the other variations mentioned above
2010 E92 ///M3 DCT LCi "Croxley Tuned" Ka-boom
2012 F25 X3 3.0d
The following 1 user Likes 922-ZN's post:
  • Kish2604
Reply
#10
Agree with Bazza, did the same with my X5 30d and a downpipe, it has made a world of difference to the cab. Happy for you to take the cab for a drive to see the difference if you are in Jhb. Did mine with Sherwin and the guys at the 357. Excellent service
Reply
#11
(21-05-2020, 03:47 PM)922-ZN Wrote: @Kish2604 is correct, from the F15 line, 30d engine code is N57N, 40d is N57Z and 50d is N57X, with the 50d using a different piston and rod according to part numbers at the very least, along with the other variations mentioned above
If the internals are different, that is probably how the different engines will be labeled. However, as per the OP's screenshot, the engines seems to be exactly the same because they are N57D30 for F15 line, 30d, 40d and 50d. So, where can we check you story?
Cartel
Current:
Ex:
2011 C350 CDI
Reply
#12
www.realoem.com
2012 F25 X3 3.0d
Reply
#13
The engines are different, almost everything is different from 30d/40d/50d with the exception of the ecu!
[Image: traction-control-malfunction-automobile-...tive-5.png]
Reply
#14
You mention some words which spark a very eay answer for you "simpler" "Other Issues" "Daily drive"
Go drive the 30d that was done by Sherwin, and then decide from there how far you want to stretch into...you want a simple and reliable daily drive with power to punch when you need, a well boosted and maintained 30d is not bad at all.
Current:
2013 EB BMW M135i F20 - Xcede Tuned - 264wkw/635wnm
2016 Ice White Hyundai ix35 R2.0 CRDi Elite -
2008 Silverbird Grey VW Polo 1.4i Trendline
Gone but never forgotten:
2011 Mercedes-Benz C250 CDi BE Avantgarde - Madness Tuned
2010 Titanium Silver BMW 320d Exclusive E90 LCi - Chiplogic Tuned
2008 Stratosgrau Stratos Grey BMW 320i Individual E90
Reply
#15
[attachment=817 Wrote:     S1NGH 911 pid='1430704' dateline='1590076916']
Please point us where we can find information supporting your statement. Below is the information saying the 30d/40d and 50d uses the same N57D30 Engine. You can also see that the 25d, 35i and 50i uses different engines as shown which is clearly shown by different numbers i.e N47D20,N55B30 and N63B44TU
I will agree with @Kish2604 that the difference is with the components around the engine, like intercoolers, injectors, piping, intake manifolds, etc and the ECU. But the engines are the same, with the same internals unless someone can prove me wrong with a solid information.  Tiptoe
Cartel
Current:
Ex:
2011 C350 CDI
Reply
#16
Quick look at just a few part numbers on https://www.realoem.com - 2019 30d vs 50d
30d - B57D30A
Short engine: 11002455913
Cylinder head: 11128571119
Piston: 11258598757
50d - B57D30C
Short engine: 11002457404
Cylinder head: 11128575787
Piston: 11258575411
Reply
#17
30d - B57D30A
Piston: 11258598757
50d - B57D30C
Piston: 11258575411
Now we are talking about different engines here, OP's questions is in relation to the N57D30 engines and not the B57D30  dunno anymore
Cartel
Current:
Ex:
2011 C350 CDI
Reply
#18
30d - B57D30A
Piston: 11258598757
50d - B57D30C
Piston: 11258575411
Sorry about that
X5 F15 30d vs 50d
N57D30A
Short engine: 11002354608
Cylinder head: 111278129271
Piston: 11257812585
N57D30C
Short engine:11002355858
Cylinder head: 11128573401
Piston: 11258506105
Reply
#19
30d - B57D30A
Piston: 11258598757
50d - B57D30C
Piston: 11258575411
What part of this do you not understand: N57N, N57Z, N57X
The D30 simply means 3.0L
Yasis the bakery opened early this lockdown!
Reply
#20
30d - B57D30A
Piston: 11258598757
50d - B57D30C
Piston: 11258575411
Interesting thread, thought the engine internals would be the same. This is only what I have found. I don’t mean to cause any confusion. Anyway time for the bakery to close
30d: N57N - short engine pn: 11002354608 N57D30A
50d: N57X - short engine pn: 11002355858 N57D30C
[Image: 96ae0a8dd480f885aed58cf29cd907c4.jpg]
[Image: 69211b7cd014ccf157314670be5a814a.jpg]
[Image: 91eda00215281c040215d123e26f335f.jpg]
[Image: 470dcf019dc385a8b4dfd3c88e5c944e.jpg]
The following 2 users Like Quintin140's post:
  • lebofa, mathias
Reply
