Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW E36 REAR SWAY BAR END LINKS
#1
Hi guys,
Been having a bit of a run for money installing new rear sway bar end links on my E36 (don't judge haha). Please see the picture attached. Its a Lemforder link, same part number as my BMW one.[Image: end%20link_2688618242.png]
As you can see in the picture, the hole diameter of the new link is smaller than the one i took out the car. Anyone has any ideas on how to get the link to slide onto the sway bar? I have tried greasing it and knocking it in but that just got it slightly over the sway bar and then it was stuck again.
Any advice from your experiences?
Reply
#2
Since having my 1er I have forgotten a lot of info on the E36 lol
I do know that there were some different size OEM sway bars for the E36. It that endlink hole look like it might be meant for another bmw model but I could be wrong
I recon heat up the rubber and try push it on the sway bar just be careful you don’t push out the bushing app use a socket or something to get it on the sway bar.
I wouldn’t try to drill the hole bigger as the would probably be better to throw it away
Another option is to try make a diy bushing using windscreen silicone. Basically diy poly bushes
Ps heating the busing might also damage it so keep that in mind
Reply
