Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW 318is Lightweight flywheel
23-03-2020, 06:49 PM,
#1
Hi Guys,
I'm looking to do a light weight flywheel and clutch conversion on my M44 318is,
Any advise and is there a parts list of what I require?
Sent from my SM-G950F using Tapatalk
24-03-2020, 09:37 AM,
#2
Why? You're not going to gain anything worthwhile
Sent from my HD1901 using Tapatalk
24-03-2020, 09:39 AM,
#3
RE: BMW 318is Lightweight flywheel
(24-03-2020, 09:37 AM)wikked Wrote: Why? You're not going to gain anything worthwhile
Is this not a good idea?
24-03-2020, 09:41 AM,
#4
On a daily? Nah.
24-03-2020, 10:33 AM,
#5
No performance gains other than your motor to spin up quicker which will improve your acceleration but it will also drop revs quicker between gears.
I like doing mods so I would have probably done it
You can get a single mass custom flywheel which will use oem 318is clutch
last I checked it costed around 4-5k depending how far you wanna go
I got someone who can do this for you if you want to do it.
I recon do some research before doing this
24-03-2020, 10:52 AM,
#6
You're not going to get any acceleration benefits. A lightened flywheel won't in any way affect gear ratios or power output.
24-03-2020, 10:59 AM,
#7
(24-03-2020, 10:52 AM)wikked Wrote: You're not going to get any acceleration benefits. A lightened flywheel won't in any way affect gear ratios or power output.
You are right it wont increase power or gear ratios
But the motor will spin up quicker causing it to increase acceleration
https://www.rx7club.com/2nd-generation-s...on-228442/
24-03-2020, 11:02 AM,
#8
Sigh. No. That's not how acceleration works.
24-03-2020, 11:05 AM,
#9
Ok well that’s my understanding
Users browsing this thread:
1 Guest(s)
Return to Top
