Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Radiator advise needed
#1
Morning Boys,
So last night on my way from work towards home on the N1 my coolant light comes on. On the Audi, was close to menlyn so nursed the car to morther in laws house for further inspection. To find out that the water bottel is full of emptieness Fencelook.
So the temp stayed normal / just below normal the whole of 5km.
Filled her up witn some H2O and nursed her home the additional 12km from skoonma to my house.As i stopped in front of the gate the light comes on again. Pulled this troublesome lady onto my ramps, remove the bash plate and see some water dripping from the radioator. So i think the plastick expantion tanks cracked. (F....)
Anyways im in 2 minds, do i get a replacement from a shop or do i get my guy to weld on alu tanks? It going to cost the same ish...
If the recomendation is to replace, i have 2 brands i have been quoted on TYC (dont know this brand at all) and BEHR.
Both come with 12months warantee and full aloy tanks is for "life".
Thanks for reading
Current ladies
Toyota corolla 130 1996 DD
Diahatsu terios 4x4 1.5 The family wagon
EX LADIES
- E46 318 Touring Alpine white 03'-*Sold
- Honda BROS NXR125ES red 07'-DD *sold
- Opel corsa 1.4 white 07'-sold
- VW FOX 1.3 blue matalic 89'-sold
- Opel corsa ute 1.4 silver 05'-sold
- Ford laster 1.6 white 95'- write off
- Ford bantam grey 1.6 990'-sold
[Image: img_20160718_210818_8745185299.jpg]
Reply
#2
Replace with Behr. Behr radiators were OEM parts on the E46 and they supply some other parts to BMW under the 'Mahle' name.
Had my radiator changed to a Behr brand in 2015, purchased through Silverton. Silverton can also do a pressure test to make sure you are replacing the correct part.
The following 1 user Likes KPM_330's post:
  • Stephanv
Reply
#3
Thanks Ty
Current ladies
EX LADIES
Reply
#4
Behr would be my suggestion as KPM has mentioned.
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo%20from%20sashchern_5592516823.jpg]
Reply
#5
Agree on doing a pressure test first. In the past I replaced pipes, and a bottle, and even the radiator, and it turned out my bottle cap was the problem. facepalm
"The Future is not set, there is no fate but what we make for ourselves."
The following 1 user Likes Coisman's post:
  • Danny@DSCmotorsport
Reply
#6
(13-11-2019, 10:49 AM)Coisman Wrote: Agree on doing a pressure test first. In the past I replaced pipes, and a bottle, and even the radiator, and it turned out my bottle cap was the problem. facepalm
Start with this and make sure its the radiator
Reply
#7
Thank you all for the replies. it is definitely the rad. Praise
Current ladies
EX LADIES
Reply
