Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
How to remove m135i charge pipe? Help..
#1
Doing some upgrading to the sleeper.
I am removing charge pipe off the m135i. Took off bottom engine cover and disconnected pipe at intercooler. Disconnected at throttle body. Disconnected all sensors etc.
Before I take half the car apart haha, what’s the quickest way to get Oem charge pipe out ?
Reply
#2
need to disconnect the Map sensor and disconnect the vacuum pipes that are connected to the chargepipe.
After that its a matter if wiggling till its out
Reply
#3
Thanks. All is removed. I just can’t wiggle it out. It seems I have to either remove the intercooler or something else to get it out.
Do you take it out top ?
Reply
#4
Nope nothing else needs to come out to remove the pipe
Reply
#5
It can be done without removing the intercooler, however I recommend that you to take make your life easier. You could also use the opportunity to clean up the cooler. smile bounce
Reply
#6
My answer for everything Youtube, they really have everything on there.
Search kies motorsport they have plenty how to videos
The following 1 user Likes Taran Rodrigues's post:
  • Veteran
Reply
#7
There is also a water pipe bracket that needs to be moved out the way, remove the press clip and off you go. It is a two person job wiggling the stock pipe out.
PS. i always took it out the top...
Current: Danger Ranger
Ex E92 335i DCT
400m @ 11.516 @ 203kmh
Backed up at MSA event!
60-130mph - 8.3 seconds
Dragtimes.com
Time is the best teacher.. Unfortunately it kills all its students Bangdesk
The following 1 user Likes Kish2604's post:
  • Veteran
Reply
#8
(11-11-2019, 01:09 PM)Kish2604 Wrote: There is also a water pipe bracket that needs to be moved out the way, remove the press clip and off you go. It is a two person job wiggling the stock pipe out.
No water pipe needs to be removed to take he chargepipe out.
I have over 30 of these without removing the water pipe.
It also doesn't require 2 people
Reply
#9
i said bracket to be moved... not waterpipe to be removed, its a small but subtle difference....
Ex E92 335i DCT
Dragtimes.com
Reply
#10
(11-11-2019, 03:02 PM)Kish2604 Wrote: i said bracket to be moved... not waterpipe to be removed, its a small but subtle difference....
either way, water pipe or water pipe bracket its still something that doesnt need to be removed.
Hammerhead
Reply
