Post Reply
Thread Rating:
  • 2 Vote(s) - 4.5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Yatour YT-M06 Question
04-06-2019, 08:49 PM (This post was last modified: 04-06-2019 09:37 PM by GPGrobler.)
Post: #1
Hi all,
When installing this unit in my E46, do I have to disconnect the OE CD changer completely to make the Yatour unit work?
Thanks in advance for the help. Thumbs
Very strange, the radio still "talks' to the CD changer, but it is unplugged from the back of the radio, and the Yatour is plugged in in its place ...
BMW E30 318i ///M Tech 1989, BMW E46 320i 2002, BMW E46 323i 2000
Find all posts by this user
05-06-2019, 07:01 AM
Post: #2
RE: Yatour YT-M06 Question
Doesn't anyone else use this unit?
05-06-2019, 07:21 AM
Post: #3
Hi
Just read up on the device and this looks interesting... I have no input to help but would like to see the write up she pictures when you’ve installed it.
Current:
2001 BMW E46 330i
2014 BMW F20 116i
05-06-2019, 10:48 AM
Post: #4
(04-06-2019 08:49 PM)GPGrobler Wrote:  Hi all,
I had one in my VW and essentially you are replacing the CD changer for the Yatour, the Head unit still sees a 'cd changer'
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo from sashchern_5592516823.jpg]
07-06-2019, 08:24 PM
Post: #5
I plugged in the wiring harness provided with the Yatour but it gets no power, the CD changer still has power.
12-06-2019, 04:10 PM
Post: #6
Mystery solved, I got the wrong wiring harness with this unit, so now I need to find someone who has installed one with the correct harness in the trunk of their E46, so that I can modify this harness for the unit to replace my cd changer in the trunk. FencelookFencelookThinkingThinkingThinking
13-06-2019, 01:53 PM
Post: #7
(12-06-2019 04:10 PM)GPGrobler Wrote:  Mystery solved, I got the wrong wiring harness with this unit, so now I need to find someone who has installed one with the correct harness in the trunk of their E46, so that I can modify this harness for the unit to replace my cd changer in the trunk. FencelookFencelookThinkingThinkingThinking
Are there numbers or identifying features on the harness? The only power came from the headunit in my case, i assume your is expected to get power from the OEM changer cable?
Current Rides
2012 X1 2.0D MSport
1996 200 Si Camry
13-06-2019, 03:24 PM
Post: #8
Isn’t it supposed to get power from the head unit? Since you have to plug it in at the back? Because there is two ports you can use
Current:
2001 BMW E46 330i
2014 BMW F20 116i
06-09-2019, 11:08 AM (This post was last modified: 06-09-2019 12:07 PM by GPGrobler.)
Post: #9
Heads up: When you order the Yatour unit for the BMW E46 with the CD shuttle in the trunk, make sure you get the *BM4* unit, where the wiring harness connects to the car's CD shuttle harness. NOT the BM1 unit where the harness plugs into the back of the radio.
You will also need a constant 12V source in the trunk and a switched 12v source for the ACC wire of the BM4 harness.
I attached the ACC wire to a switched source in the trunk, but this is annoying because the Yatour then only works in the KEY 2 position.
Will keep you guys posted how I solved this problem.
Another neat idea that I did with my Yatour is that I upgraded it to Bluetooth 4.0 with this nifty little gadget: https://www.amazon.com/Bluetooth-Receive...B07D3JYBFK
12-09-2019, 08:07 PM
Post: #10
Can anyone please give info on how the files are set up on the usb flash drive.
Post Reply
User(s) browsing this thread:
1 Guest(s)
