Thread Rating:
  • 2 Vote(s) - 4 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW E83 X3 Lower Steering shaft removal
#1
Hi all,
I am doing a cylinder head replacement on my E83 X3 3.0si, and the only way is to remove it with the exhaust manifold still attached. The steering shaft must be removed though, which I have disconnected. The problem I have is that I can't figure out how to get it out, as the exhaust still catches on it when trying to remove the head.
Want to avoid fiddling with the steering tie rods if possible. Anybody tackled this job, all help greatly appreciated.
cheers,
Jason.
Reply
#2
why cant you remove the branch manifold?
Current: 2005 E55 AMG
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 1998 BMW M3
Ex: 2011 REVO 2 Focus ST - 208wkw & 465nm's (FRnR)
Ex: 1994 E36 328i Track Car (Budler Motorsport built)
Ex: 2011 REVO 2 Mk6 GTI DSG - 200wkw & 452nm's (KAR)
Ex: 2007 REVO 2+ S3 - 12.7s @ 176km/h (Tarlton 2010) and 224km's on 1km (ODI 2010)
Ex: 2006 Velo 1.6i | 2008 Velo 1.6i | 2005 Velo 1.4i | 2006 Polo 1.6i | 2012 Polo TDI | 2004 W203 C200K
Reply
#3
(17-05-2019, 12:56 PM)johndoe Wrote: why cant you remove the branch manifold?
I literally can't reach all the nuts from above and below, the aircon hoses are right up against it, and the steering column is also in the way. I spoke to a local mechanic who specialises in BMW's, and he said steering must come out, and the manifold will come out with the head.
BlueCry
Reply
#4
Once again the engineers tried to screw the mechanics/technicians... Thumbdown
The following 1 user Likes johndoe's post:
  • BMWfanforever
Reply
#5
BlueCry
Good luck dude
This the M54 3.0l in it?
The following 1 user Likes evnmopwr's post:
  • BMWfanforever
Reply
#6
What if you loosen the engine mounts, and jack the motor over to the passenger side to give you some more room to either get the bolts loose, or some more space to pull the head out
The following 2 users Like CA_130's post:
  • BMWfanforever, evnmopwr
Reply
#7
(17-05-2019, 02:09 PM)CA_130 Wrote: What if you loosen the engine mounts, and jack the motor over to the passenger side to give you some more room to either get the bolts loose, or some more space to pull the head out
This is the exact reason i asked if his car is the M54. Thumbs
That is how i got mine out on my 320i E46
Reply
#8
3.0si implies N52 motor.
Nothing comes at a higher price than that which is free.
330i
The following 1 user Likes Blue Shirt's post:
  • evnmopwr
Reply
#9
(17-05-2019, 03:19 PM)Blue Shirt Wrote: 3.0si implies N52 motor.
Thanks for confirming...Thumbs
Reply
#10
Another option is to remove or loosen the steering rack. If you mark the locking nuts on the tie-rods you should be able to get the toe-in close enough to spec to drive to an alignment centre.
330i
Reply
#11
BlueCry
Good luck dude
Thanks man,Thumbs I bit off a crap load tackling this job. No it's the N52 3.0si motor. One of the eccentric shaft stops broke off in the head. Whole head replecement, and BMW wants R72 grand for a new head. Rofl Doing the job myself, and getting recon unit from Steves Auto clinic.
Thant's a great idea, thanks!Thumbs Will give it a try tomorrow. I tried worming it out by myself last night but the damn thing weighs like 45kg without the manifold and I'm not a spring chicken anymore.
Reply
