Too much speed
14-02-2019, 01:35 PM
(This post was last modified: 14-02-2019 01:48 PM by graan13.)
Post: #1
Too much speed
Got this from a UK forum for e60's
Apparently snow/ice and speed..... hit 2 tree's among other things!!! Incredibly occupants were ok apart from bumps n bruises ![]() other side..... ![]() ![]() The senior King - Simply, the best!!! You are missed....... |
14-02-2019, 04:21 PM
Post: #2
RE: Too much speed
someone actually walked away from that? I guess it just wasn't his day
14-02-2019, 04:23 PM
Post: #3
RE: Too much speed
Drivers side shows minimal damage so yhea you should walk away from it if you were sitting on that side correctly strapped in.
Yesterday, 08:44 AM
Post: #4
RE: Too much speed
OMW, second time this week that i've seen a 5er show its worth in these situations.
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides 2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels) 2012 X1 2.0D MSport 1996 200 Si Camry ![]() |
Yesterday, 12:29 PM
(This post was last modified: Yesterday 12:31 PM by graan13.)
Post: #5
RE: Too much speed
(14-02-2019 04:23 PM)Rotinaj Wrote: Drivers side shows minimal damage so yhea you should walk away from it if you were sitting on that side correctly strapped in. Apparently 3 in the car and think the accident was in Scandinavia somewhere which would imply a LHD. If you look at the right side photo there is no steering wheel visible ![]() The senior King - Simply, the best!!! You are missed....... |
Yesterday, 12:33 PM
Post: #6
RE: Too much speed
(14-02-2019 04:23 PM)Rotinaj Wrote: Drivers side shows minimal damage so yhea you should walk away from it if you were sitting on that side correctly strapped in. I think you referring to the passenger side. The side with less damage doesn't have a steering wheel. Although that could explain the accident.... the driver was in the wrong seat ![]() |
« Next Oldest | Next Newest »
User(s) browsing this thread:
1 Guest(s)
1 Guest(s)
