Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
New X4M and X3M Go Official
13-02-2019, 06:06 AM
Post: #1
Highlights:
3.0L Twin Power Turbo inline 6 cylinder (S58) engine
473 HP / 442 LB-FT (Standard model)
503 HP (Competition model)
0-60 in 4.1 seconds (standard model)
0-60 in 4.0 seconds (Competition model)
155 MPH top speed (electronically limited)
174 MPH top speed (for standard model if optioned with M Driver's Package)
177 MPH top speed (for Competition model if optioned with M Driver's Package)
Production begins April 2019
Engine / Exhaust
473 HP (standard model) and 503 HP (Competition model) from 6250-7200 RPM
442 LB-FT torque from 2600-5600 RPM (standard model) and 2600-5950 RPM (Competition model)
Forged crankshaft
7200 RPM redline
Closed deck design
Wire-arc sprayed-on iron coating for cylinder walls
3D printing technology cuts weight of cylinder heads
Two mono-scroll turbochargers
350 bar maximum fuel injection pressure
Valvetronic and Double-VANOS variable camshaft timing
100 mm exhaust tailpipes
M Sport exhaust system standard for Competition models
Transmission / Cooling
8 Speed M Steptronic transmission with three shift modes
M xDrive intelligent all-wheel-drive system
Active M Differential (allows rear lockup between 0-100%)
Cooling
One large central radiator and two smaller radiators sides
Engine oil cooler and a separate transmission oil cooler
Lightweight oil sump has two separate chambers and an integrated suction channel
Chassis / Suspension
Strut brace in the engine compartment that links the shock towers
Carbon fiber strut brace will be available as an option beginning August 2019
A-strut in front section near the firewall, with two further struts increasing stiffness between the shock towers and the front of the car
Large rear brace and model- specific rear axle control arms
Double-joint spring strut front suspension and Five-link rear suspension feature model- specific bushings
Custom-made swivel bearings, torque arms and wishbones in front suspension
Increased front wheel camber
Model-specific components and custom bushings in rear suspension
Stiff camber arm
M-specific rubber mounts for all control arms and the rear suspension subframe
Model-specific anti-roll bars (larger bars on the Competition models)
Adaptive M Suspension controls damping forces for each wheel individually
Steering
M Servotronic system combines speed-sensitive power assistance and a variable ratio
Steering response can be varied by pushing a button to select one of three settings
Brakes / Wheels / Tires
Four- piston fixed front calipers and single-piston floating rear calipers at the rear
Drilled, inner-vented brake discs measure 395 millimeters (15.6 inches) in diameter at the front and 370 millimeters (14.6 inches) at the rear
Cast- iron brake discs with aluminum hubs
M light-alloy wheels in V-spoke design and mixed size high-performance tires (non-runflat)
20-inch wheels in polished Orbit Grey finish with 255/45 ZR20 tires at the front and 265/45 ZR20 tires at the rear (standard model)
21-inch wheels with a polished Jet Black finish with 255/40 ZR21 tires at the front and 265/40 ZR21 at the rear (Competition model)
Exterior / Colors
Seven exterior colors, including new Toronto Red metallic and M-exclusive Donington Grey metallic.
Competition Model
Standard equipment on the Competition models includes:
21-inch M light-alloy wheels in polished Black
M Sport exhaust system with tailpipes in Black Chrome
Specially designed door sill plates and model badging
M Carbon Exterior Package
Optional M Carbon exterior package (expected to be available from August 2019), will feature design elements in carbon fiber- reinforced plastic (CFRP) for the front air intakes, the air blades in the front apron, the rear diffuser and the exterior mirror caps
On the BMW X4 M and BMW X4 M Competition, these elements will be joined by a CFRP rear spoiler
Interior
Standard: heated sports seats in Vernasca leather with embossed M logo
Optional: M Sport seats in extended Merino leather (standard on Competition model)
Vernasca leather upholstery in a choice of Black or Oyster with an embossed M logo at the top of the backrests,
Interior trim strips in Aluminum carbon structure.
Competition X3M and X4M come standard with M Sport seats in extended Merino leather upholstery that can be specified in either Black or bi-color choices in Sakhir Orange/Black or Adelaide Grey (optionally available for standard models)
Optional extras include BMW Individual extended Merino leather upholstery in Ivory White and Tartufo (only in conjunction with the M Sport seats) and Carbon Fiber interior trim strips.
Extended Merino leather upholstery in the new Midrand Beige/Black color choice with Alcantara applications is available exclusively for the BMW X3 M Competition and BMW X4 M Competition models
Standard and Optional Equipment
Standard:
Adaptive Full LED lights
Harman Kardon surround sound audio system
SiriusXM Satellite radio with 1 year subscription
Navigation with Apple Car Play compatibility
Comfort Access keyless entry
Full array of advanced driver assist systems including Active Guard, Active Protection Active Driving Assistant and Frontal Collision Warning with City collision mitigation.
Optional packages include:
Driving Assistance Plus Package with Active Cruise Control with Stop & Go and Extended Collision Mitigation
Executive Package with heated steering wheel, heated front and rear seats, parking assistant plus, head-up display, wireless charging, WiFi hotspot and gesture control.
// M Power.
Find all posts by this user
The following 2 users Like CocoPops's post:
Redshert, sanesh21
13-02-2019, 06:48 AM (This post was last modified: 13-02-2019 06:52 AM by Zach.)
Post: #2
RE: New X4M and X3M Go Official
Only interested if they come out with 5.0d versions. The petrol variants will be stupid thirsty even if you drive like a grandma. Completely the wrong engine for an suv imho, probably why they left out the fuel consumption figures on the press information, wont sell many units if they do...
13-02-2019, 08:10 AM
Post: #3
X3M looks proper!
Current:
2014 F30 330d M-Sport ZF8
2006 E90 320i A/T , Sport pack
Ex:
2013 F21 M135i 6MT - "Hercules" - FBO, Vargas stg1 - N55 PWG Stg1 turbo non nitrous WR - 342WKW (460WHP) / 698NM
13-02-2019, 08:56 AM (This post was last modified: 13-02-2019 08:58 AM by individj.)
Post: #4
im not too concerned about fuel consumption when buying an //M so this is perfect!
these vehicles weigh about 100kg more than a M4 convertible
current: BMW E92 M3 (bearings could be fcukd)
13-02-2019, 10:17 AM (This post was last modified: 13-02-2019 10:33 AM by M-factor.)
Post: #5
Not a fan of high performance SUV's but man does that X3M look good!
[Image: first-ever-bmw-x3-m-2000_9002700950.jpg]
The following 2 users Like M-factor's post:
Bmw.wp, Quintin140
13-02-2019, 12:48 PM
Post: #6
So how about the new S58 engine....
375kw and 600nm Praise
Current Ride:
2016 VW Golf Mk7 GTI Clubsport
Previous Rides:
2011 VW Golf Mk6 R - Manual/DCC/Dynaudio/Recaros
2007 VW Golf Mk5 GTI (REVO 2)
2013 VW Polo 6R GTI (REVO 2)
2011 VW Scirocco GT 2.0TSI DSG (REVO 3)
2010 VW Golf Mk6 GTI DSG (REVO 2)
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
13-02-2019, 01:39 PM
Post: #7
(13-02-2019 12:48 PM)Le Clue Wrote:  So how about the new S58 engine....
hell yes
13-02-2019, 01:44 PM
Post: #8
(13-02-2019 06:48 AM)Zach Wrote:  Only interested if they come out with 5.0d versions. The petrol variants will be stupid thirsty even if you drive like a grandma. Completely the wrong engine for an suv imho, probably why they left out the fuel consumption figures on the press information, wont sell many units if they do...
Look at the amount of GLC43s, GLC63s, GLE43s and GLE63s on the road, it's actually in demand.
Current Cars:
2017 F80 M3 ZCP
1991 325iS - Henna Red, Link: http://www.bmwfanatics.co.za/showthread.php?tid=47188
2015 Kawasaki ZX10R 30TH Anniversary Edition... Greeeen!
Ex:
2012 Kawasaki ZX6R - Greeeen!
2011 P31 C63 - White, Link: http://www.bmwfanatics.co.za/showthread.php?tid=54942
13-02-2019, 01:50 PM
Post: #9
(13-02-2019 08:56 AM)individj Wrote:  im not too concerned about fuel consumption when buying an //M so this is perfect!
This
Sent on the move using Tapatalk
330d E90 LCI DP & SW
2.0d F25 X3 - Hers
320d E90 LCI - Ex
328i E46 - Ex
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
#NoLivesMatter
The following 1 user Likes tman's post:
individj
15-02-2019, 09:57 AM
Post: #10
I am honestly thinking the X4M is the next BM to have... Love the X4 and with 375kw... man.. Praise Now I just need to find the 1.5bar it will cost Fencelook
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
[Image: m_fanatic2_8387882621.jpg]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
15-02-2019, 10:48 AM
Post: #11
(15-02-2019 09:57 AM)cOlDFuSiOn Wrote:  I am honestly thinking the X4M is the next BM to have... Love the X4 and with 375kw... man.. Praise Now I just need to find the 1.5bar it will cost Fencelook
X3M and M2 =)
15-02-2019, 10:57 AM
Post: #12
I dont understand how they can justify these hideous and good-at-nothing things, but can't do an M3 Touringdunno anymore
And the reason I say good at nothing, is simply because everything is compromised.
Its not a proper offroader, because ground clearance, big anti roll bars, low profile tyres....
And its also not a proper sportscar, because its heavy, topheavy and pretends to be able to go off the tarmac......
Its not economic......
So what is it really?
[Image: FordTappetcover1.jpg]
If everything seems under control, you're just not going fast enough - Mario Andretti
15-02-2019, 11:04 AM
Post: #13
(15-02-2019 10:57 AM)Fordkoppie Wrote:  I dont understand how they can justify these hideous and good-at-nothing things, but can't do an M3 Touringdunno anymore
i hear you....well i suppose if you weren't going to take it to the track...its your "//M3 touring"
15-02-2019, 11:08 AM
Post: #14
(15-02-2019 11:04 AM)individj Wrote:  its your "//M3 touring"
Its not....
Because its too heavy, too high, too AWDRofl
15-02-2019, 11:14 AM (This post was last modified: 15-02-2019 11:15 AM by individj.)
Post: #15
Its not....
actually doesn't weigh that much more..get some H&R springs & a JB4 and boom Hammerhead
i actually have no experience with BMW AWD...my audi AWD confuses me when going sideways hahaha
15-02-2019, 12:51 PM
Post: #16
Yes, it was never intended to be a proper offroader, hence they call them SUVs
I also bet hauling 0-100 in 4.1s will make many feel like they are in a sports car Thumbs
25-06-2019, 08:38 PM
Post: #17
https://m.youtube.com/watch?v=tvscTb1Ytq4
26-06-2019, 02:05 PM
Post: #18
X3M and X4M now have the same front end.
Only difference is you get less headroom in the back with the X4M, but I assume you will pay more for that inconvenience?
[Image: dsc_0327_edit_bmw_8373914137.jpg]
26-06-2019, 02:31 PM
Post: #19
It's really shit...
Nothing as tilting as these "BMW" offroaders... Seeing a huge X5 with one person sitting in it. Is a 5 series that much less comfy?
Previously owned cars:
2003 Alfa Romeo 147 T-Spark (Navy blue and beige interior)
2006 Alfa Romeo 147 JTD 16v (Silver and beige interior)
Current:
2007 BMW Z4M Coupe (Silbergrau and Black Leather)
26-06-2019, 03:28 PM
Post: #20
Definitely sounds better than the S55.
Post Reply
User(s) browsing this thread:
1 Guest(s)
