Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Advice on cleaning engine inside
25-01-2019, 10:16 AM
Post: #1
Good day fanatics.
Im looking for your advice...
I was riding my bike and suddenly my clutch lever went limp and my clutch would not disengage. Luck it happened just as I arrived home.
because the cable pivot was also loose I knew I had to open up the engine side cover and take a look.
My bike (not actually a bmw) uses a clutch pressure plate bearing. The bearing disintegrated and lost its balls. and the bearing side walls turned into glitter oil. I dropped the sump and eventually found all the balls.
I want to clean the engine where I can access it from the removed side cover and sump, in view to get rid of the metallic traces of the bearing before I start engine flushes with cheap oil to final oil.
Now where I need advice...My Boet as a hand pumped can thing that can squirt paraffin. can I use paraffin to clean the oil residue off the exposed gears / cogs etc? If not, what else? carb cleaner mabe?
Any thoughts are appreciated.
Find all posts by this user
25-01-2019, 10:54 AM
Post: #2
I think you tube might be your best friend on this one
Sent from my SM-G950F using Tapatalk
Post Reply
User(s) browsing this thread:
1 Guest(s)
